HELP...'91 E350 6-cyl. van
Old Sep 6, 2004 | 05:09 PM
grizzley1933's Avatar
grizzley1933
Cool HELP...'91 E350 6-cyl. van
Shuts off SOMETIMES when operating temp. is reached and then can restart when cooled down. Taken to Ford dealer 3 times, but won't shut down there. Last time I left it there for 3 days for them to run around with...ran like a clock.
Just had it out myself today...yep you guessed it...shut down after 2 miles...let it cool down and i got it back to my driveway where it shut down again. Driving me nuts. Got over $900 in this problem, so hard for me to give up on it. This is what I've done to it so far: complete tuneup with new wires, new coil, 2 new ignition modules (replaced a new one in case it was bad because dealer said most probably it was my problem), complete new distributor (dealer said next probable bad part was stator), and now i just replaced ecm (ouch), and yes still have same problem!!! i guess one of the engine sensors would be next choice.
Please any suggestions?
Desperate....Grant
Old Sep 6, 2004 | 08:19 PM
pfogle's Avatar
pfogle
Is there what looks like a blower motor under hood? Does it run? If not that could be the problem, they were installed to help with a vaporlock problem. Sound's like a fuel problem to me. I'd be checking the fuel pump.
Old Sep 7, 2004 | 05:00 PM
Yakk's Avatar
Yakk
That blower only needs to run when the truck is off.
Try the ECT engine coolant temperature sensor.
They can wreak havoc when bad.
Otherwise have a pow-wow and smoke a peace pipe with the FORD stealer errr Dealer.
-J-R-
Old Sep 7, 2004 | 07:06 PM
grizzley1933
fuel problem definitely ruled out by 2 different dealers. I also had pressure gage attached when it shut down....55lbs. there before and immediately after shutdown.
Old Sep 7, 2004 | 09:41 PM
pfogle's Avatar
pfogle
It could be the ECT (engine coolant temp) sensor, or the map sensor.
Old Sep 10, 2004 | 07:12 AM
grizzley1933
Got ect sensor. Only a $5 part??... looks like all this does is send to dash temp. gage.....Is there another one more sophisticated on engine which could cause 'puter to shut down engine?
Old Sep 10, 2004 | 11:00 AM
pfogle's Avatar
pfogle
Where does it install? It should go in the water neck or the front of the intake manifold.
Old Sep 10, 2004 | 11:10 AM
grizzley1933
replaced ect sensor and oh oh.....now temperature gage reads up at the al of normal as before changing sensor never went above the o. Now under load goes above the l. And noticed fuel line which runs up along trans. is so hot I can't hold it (trans just as hot which may be normal). Now vaporlock is crossing my mind. Later today I plan on checking fuel return line for clog (thinking this may produce vapor lock). Also when I shut engine down at high temp. the radiator fan spins freely. Fan clutch bad? Any thoughts?
Old Sep 10, 2004 | 11:14 AM
grizzley1933
ect sensor i replaced was at passenger side rear of block with one wire attached. lost a little coolant but replaced.
Old Sep 10, 2004 | 12:17 PM
pfogle's Avatar
pfogle
That's the gague sender. THere should be another one in the intake that has 3 wires in it.
Old Sep 10, 2004 | 03:45 PM
Yakk's Avatar
Yakk
The six cylinder has the sensor near the water neck for the thermostat.
It has a 2 terminal connector.
MotorCraft # DY-681
GP sorenson TSU 83
Make sure you specify SENSOR.
-J-R-
Old Sep 30, 2004 | 09:36 AM
grizzley1933
no vapor lock--that was transmission line was was hot not fuel line.
just replaced ect sensor and still shut down when op. temp. was reached....immediatly connected scanner and came back system check ok.
anyone have any other ideas?
Old Sep 30, 2004 | 11:55 AM
pfogle's Avatar
pfogle
Have you had the ICM (ignition control module) checked? IF it's a new AutoZone unit it very likely could be bad.
Old Oct 1, 2004 | 03:02 PM
grizzley1933
yes...tried 2 different new icm's
Old Oct 2, 2004 | 10:31 AM
griffe150's Avatar
griffe150
Have you checked your fuel pump relays I had a simler problem with mine looked at all the engine stuff and ended up being a lowsey relay.
JR2980
Jun 15, 2014 08:39 PM
Bbasso
25
Apr 26, 2011 01:48 AM
gopedoligist
6.4L Power Stroke Diesel
16
Apr 10, 2009 11:58 AM
cfd29
Modular V10 (6.8l)
38
Jun 14, 2007 09:40 PM
