Daytime running lights or....??
Old Sep 2, 2004 | 04:37 PM
MercuryM100's Avatar
MercuryM100
Talking Daytime running lights or....??
Is it possible (and reasonable ) to wire my lights so that they come on whenever the truck is running and shut off when the truck is turned off? I would really like to just leave the headlight switch 'on' and have the lights come on as mentioned.
Sounds like a simple issue of wiring the lights through the ignition system, but I'm not too sure if this is the right direction.
Any help would be appreciated.
Old Sep 2, 2004 | 07:41 PM
MCHinson's Avatar
MCHinson
Use a Relay
I would advise against it myself, but if you are sure you want to do it, make sure you use a relay to power the lights so you don't run all of that current straight through your headlight switch.
Old Sep 3, 2004 | 08:52 AM
MyDads64's Avatar
MyDads64
It's easy to add a "lights on" warning buzzer to remind you to turn them off when you turn of the engine. Try it, you'll like it.
Old Sep 4, 2004 | 07:07 AM
MercuryM100
Thanks for the replies!
Sounds like adding a reminder buzzer would be the right way to go!
Chad
Old Sep 6, 2004 | 06:20 PM
Mike 61Ford's Avatar
Mike 61Ford
daytime running light
there is a kit that you can buy in the LMC TRUCK book thats turns your lites on automatically.Its sells for $59.95 easely to instal youre self.
Old Sep 7, 2004 | 10:11 AM
Putt's Avatar
Putt
Try checking into a Carquest parts store. They sell a kit under their EC line part number DRL-1 that makes the headlights work like the newer rigs with daytime running lights. FWIW
Old Sep 7, 2004 | 10:40 AM
MercuryM100
Great info guys, thanks!
I'd like to keep them on all of the time if possible...so I'll check out your tips.
Chad
