Anyone know the flywheel bolt torque? Release bearing failed completely so redoing with a clutch kit , South Bend. I need to resurface the flywheel.Thanks.
IIRC it's 89 ft/lbs.
Hopefully someone will chime in and confirm or deny this.
Dang! I saw 89# in the book and torqued to that; I didn't realize that SMFs were different. I'm sure it will be fine because I actually set to 90# and them a little extra grunt after the click. They should be pretty close to 95#.
That clutch release bearing and pressure plate looks just like mine. No warning at all. I have never seen a release bearing go that bad that quick. Now I am looking for the rubber boot for the clutch fork. not having any luck, still hope someone knows a place to find one.
