Stock Power: 460
Old Sep 3, 2004 | 10:11 PM
76fordtruck's Avatar
76fordtruck
Stock Power: 460
how much power do the 70's 460's in the f250s make? i was just curious because i recently purchased one. THANKS
Old Sep 4, 2004 | 01:43 AM
The "Mad Porter"'s Avatar
The "Mad Porter"
Talking Approximately 220 Net. Varies slightly year by year...
150 at the rear wheels if you are lucky...
Use this link and look for the instructions on de smogging your truck if you are not required to emissions test any more. The increase in power and mileage will be noticable...
http://www.reincarnation-automotive....rformance.html
Regards,
SMJ/RHP
Old Sep 6, 2004 | 12:13 AM
76fordtruck
whats the torque going to be like. i bet its got to pretty gosh darn high. also, i dont think it came with smog crap so....
also, with 4.10's in the diff, with a high flow airfilter, and a bigger carb, what can i expect for gas mileage.
the thing is running like a big pile of poop at the moment and i am doin roughly 4. when i change the plugs, fix the timing(cuz its missing like mad right now) can i expect an increase to about 8-10 mpg's?
thanks
mitch
Old Sep 6, 2004 | 12:41 AM
The "Mad Porter"
Talking I have a 78 F-250 XLT 2wd...
I have recurved the dizzy and placed a holley 750 on the factory spread bore intake by modifying the EGR spacer plate with a carbide burr.
The engine has 100K on it and still has the original timing set and cam. I get about 10 MPG with single exhaust sounding like a street sweeper.
I don't have the time to port my own cylinder heads LOL...
Old Sep 6, 2004 | 12:57 AM
76fordtruck
i totally understand, all i have past the manifolds is two totally hollow cherry bombs. it sounds so mean, but it has a very dirty sound too it. very very throaty. plus about 4-5 ft of the pipes has been removed off the back. loud is probably the best explanation.
Old Sep 6, 2004 | 08:53 PM
The "Mad Porter"
Talking In 76 the 460's were pretty smogged down...
The cam was revised as was the ignition timing curve. Add to this the retarded cam timing and you can see why they were dogs.
Desmog the truck per the instructions and you will not be disappointed.
Torque net was about 400 pound feet. Mostly due to cam timing and poor ignition curve.
Ordnance
Feb 12, 2014 08:25 AM
me235
Jun 10, 2008 11:35 PM
78fordf-1504WD
Engine Swaps
Oct 2, 2005 07:37 PM
paulm
Jan 11, 2005 06:53 AM
merc460
Jul 17, 2002 02:10 AM
