Pulling codes for preventive maintance??
Old Sep 2, 2004 | 02:20 PM
mike L's Avatar
mike L
How often do you like to pull codes? I was told only to pull codes if engine light comes on. I have never pulled codes on my truck it still runs good. I have 140,000 on my 87 f150 4.9, should I change my o2 sensor? Its the only thing I haven't replace while doing my tune ups, it doesn't list a maintenance time to change it in my manual.
Old Sep 2, 2004 | 05:05 PM
EPNCSU2006's Avatar
EPNCSU2006
It might not hurt do do it on your truck, just to see. If your truck is like mine, the check engine light isn't wired from the factory, so you won't ever see it come on. You'll have to pull the codes using an analog volt meter or a small test light.
Old Sep 2, 2004 | 06:58 PM
andym's Avatar
andym
Codes can be set without the light coming on. I do it when I change the oil, just to catch anything early that might become a real problem later on.
Old Sep 2, 2004 | 07:11 PM
mike L's Avatar
mike L
If i remember correctly my check engine lite ( yellow lite) come on at 120,000 miles. i was told it was a routine lite at the milage. It was to check all my emision parts. It went out 3,000 miles later. Has anyone heard of this before?
1987 f 150 4.9
Old Sep 2, 2004 | 08:16 PM
EPNCSU2006's Avatar
EPNCSU2006
I think that is the EMISS light that is on a timer, but that's all I know of that would be timed. I had one on my truck, but I unplugged the timer module and used the wire at the back of the dash to hook up my check engine light.
Old Sep 2, 2004 | 08:30 PM
GSchretter's Avatar
GSchretter
I check .
I check my codes every 6 months.
My powersteering swtich was out and I could not figure out why my engine died when it was cold and I turn the steering wheel. The power steering switch advance the timing in order to handle the load of the pump.
I bought the $200 engine code checker from O'reilly. I use it on my 99 ford winstar also. Best investment in the world. It cost $200.00 down here to have you codes read at a deaerlship. Well that is what the dealership told me.
I always call to ask to see how much it cost to do a repair. When I am done with the repair, I go to my wife and say, see honey I saved XXX dollars. Then I take the saved money and spend it at Harrys Hotrod or Sears.
Old Sep 2, 2004 | 09:14 PM
omni's Avatar
omni
I like your logic GSchretter, I think like that too, If I can save a buck at the shop I go buy a new tool, are those code readers hard to operate?
Old Sep 3, 2004 | 07:25 PM
mike93's Avatar
mike93
i like to check for codes about 2 times a year. many times the MIL will not light up when certain codes are set. usually MIL will come on when the ECU loses connection with a device or there is failure of a device.
Old Sep 3, 2004 | 11:59 PM
GSchretter's Avatar
GSchretter
Code Read.
No very easy.
The reader tells you the code number and then what the code stands for.
I just fixed my wifes dad f-150.
He was getting engine codes.
I checked them
Fuel Rail 0 and 1 running lean.
Hooked up on of those can fuel injector cleaners and it runs fine.
Dealership told me it would have costed him $300.00. Instead I paid for the $10.00 can so he got it done for free.
Beastlyforddude
Feb 16, 2011 01:54 PM
Quick444
Feb 19, 2009 09:58 AM
John7894
Apr 1, 2007 03:40 PM
luke245
Dec 9, 2006 02:15 PM
goalee29
Mar 26, 2005 11:10 AM
