Excursion blowing starter fuse
Old Jul 16, 2009 | 11:21 AM
rcraig's Avatar
rcraig
I have searched the forums and cant find relief so Im reaching out. I have a 2000 excursion V-10. Started two weeks ago the truck wouldnt start, starter wouldnt crank nothing. Traced it down to the fuse in the dash. Replaced that and it worked fine for a week. Then happened again. I traced the wires through the plug in the firewall, then to what looks like a starter solenoid mounted on the firewall. Followed that wire down to the starting solenoid on the actuall starter, not shorted out all looks good. So I replaced the starter. Still have the problem. But now its only when the engine heats up and runs a while.
I disconnected the small (activator) wire from the Fender mounted solenoid and used a fused jumper to activate and start the truck at least 20 times. It worked every time never popped the fuse. So it seems to me the problem is somewere in the dash, column or??? Im pulling my hair out! thankfully I still have enough before I get to thin.
If you can help me I would really appropriate it. Hopefully someone has had the same issue or a Ford Tech has seens and c an identify the problem.
Thank you in advance for your help
Old Jul 21, 2009 | 03:39 PM
Dereck's Avatar
Dereck
Hi Rcraig
This is going to be tricky to find all you can do is play follow the wire.
When you crank power flows from fuse 20 down a White/Pink wire to the TRS (Transmission Range Sensor, AKA Neutral Safety Switch) through the TRS and along the Tan/Red wire to the starter relay on the fender anywhere alnog this route could have an intermittant short to ground, the White/Pink wire also loops back into the fuse board to fuse 21.
Here is a wiring diagram that may help you.
I think my first move would be to disconnect the Tan/Red wire from the starter relay, have some one turn the key to crank and then give all the wiring a wiggle to see if the fuse blows.
If the fuse doesn't blow then maybe it's the starter relay at fault, If the fuse blows at least you have eliminated the starter relay as the cause, I would then disconnect the TRS and once again wiggle all the wiring see if the fuse blows.
Regards
Dereck
fordatic
Sep 23, 2016 01:28 PM
wwhitcomb1973
1983 - 2012 Ranger & B-Series
Dec 26, 2015 12:47 AM
Janet_W
1997 - 2003 F150
Oct 22, 2015 08:04 PM
Robbig34
Oct 14, 2013 08:47 AM
clean concepts
Jan 14, 2012 07:51 AM
