Low, or no compression
Old Sep 1, 2004 | 09:05 AM
john griffin's Avatar
john griffin
Question Low, or no compression
My son's 82 F-100 with a 300, L6, got hot and died on him, we towed it home and tried to start it and it turned very easy on the starter, ran a compression check and all cyl. had no or very low compression. We checked the timing gears and they looked good, steel too which is good, Will these heads crack easy, or warp.
Old Sep 1, 2004 | 02:04 PM
fordflaresides's Avatar
fordflaresides
I've never heard of the 300 heads cracking or warping easy however I've heard of early valvetrain failure maybe the valves aren't sealing causing low compression next I would lean towards piston rings or head gasket.
Old Sep 1, 2004 | 07:43 PM
f100guy's Avatar
f100guy
probably head gasket, with that low compression, you should be able to see water in the oil. check it and the radiator for oily water,
Old Sep 1, 2004 | 07:57 PM
StarFox's Avatar
StarFox
I'm with F100Guy here. You stated that it got hot and died - head gasket was the first thing that came to my mind.
Old Sep 1, 2004 | 08:02 PM
f100guy's Avatar
f100guy
yeah i had a 300six in a 71swb f100(hence the name) and the water pump belt broke and it busted the radiator and i am guessing the head gasket, i did not keep it long after that but i know it had steam everywhere and white oil. it would miss very bad until upper rpms and it still missed then. i just got an idea maybe i will try to get it back. i traded it for a 76 mustang II with a 4 speed that needs title work.
Old Sep 2, 2004 | 06:45 AM
john griffin
Thanks for all the info, we pulled the head last nite and had a blown head gasket, and 4 cracks around the valves and part of one valve as missing, man we need a good used head.
Old Sep 8, 2004 | 02:24 PM
freeF250's Avatar
freeF250
I recently picked up an F-250 flatbed with a blown motor. I'm mentioning this as a word of caution - the motor had low compression due to a shaky valvetrain, so the PO had the head rebuilt to the tune of over $700. The rebuilt head caused the piston rings to go as the motor couldn't handle the newfound compression, and eventually one of the rods decided to exit the block stage left. Amusingly enough, he limped the truck 30 iles home and I drove it to my place like this - now just over 70 miles on a blown engine! Goes to show how tough these things are.
Why am I telling you this? I got a used motor out of an '84 van to replace my gem, and that pretty little head is up for sale. As I warned, it could cause other problems, but my motor had 208,000 on the clock when the head was rebuilt. The rebuilt head has less than 500 miles on it.
As for price, make an offer. If you look at my username it kinda hints what I paid for the truck - I'm hoping to get my expenses back on the replacement power plant. I'm not looking for a fortune, but I do know what they're selling for on Ebay.
Old Sep 8, 2004 | 04:07 PM
freeF250's Avatar
freeF250
email me at littlegasengines@chartermi.net if you're interested
Old Sep 8, 2004 | 04:09 PM
f100guy's Avatar
f100guy
this also happened on a 76 mustang that i traded my 71f100 for, newly rebuilt and ported heads sucked the rings off or what ever i was told. i know it didn't run.
Old Sep 8, 2004 | 05:27 PM
50_Buck_Work_Truck's Avatar
50_Buck_Work_Truck
Yeah, fresh heads+tired block=blue and grey smoke out the tailpipe and dirty plugs for sure. Neighborhood mosquito control. Even if the compression's good and the pistons aren't swimming laps in an Olympic pool, the oil control rings could still be worn enough to sneak a bit by...
