Question on towing capacity..
Old Aug 31, 2004 | 09:06 PM
2003150's Avatar
2003150
I have a 2003 150 supercab..w 5.4 v8..Class 3 towing group...3.55 rear limited slip axle,17 inch tires,and sticker saye 6500 gvwr pkg...i just bought a TT with 5600 unloaded..
Am i going to have a problem towing?for some reason i thought i had 7700 lbs gvwr because of the towing pkg and 17 inch tires.any input is welcomed.
thanks
Louis
Old Sep 1, 2004 | 06:33 AM
trike1946's Avatar
trike1946
Welcome to FTE. You should be ok. I have a 4.6, with 3.55 and 17 inch tires and can probably tow that much. I am not sure but I think shorter tires can help tow more. Taller tires are good for mpg. Take it easy until you are used to the weight. Good luck with it.
Old Sep 1, 2004 | 08:32 AM
SoFla David's Avatar
SoFla David
with all these posts about towing capacity lately, I thought I just had to post this.
this is what can happen if you go over (really over) the tow capacity of your vehicle:
The server is a little slow, so you will probably get better results saving it to your desktop (right-click and select "save target as") and playing it from the desktop.
Definitely worth the time though.
http://home.hot.rr.com/spikesoldier/v8hill.wmv
Old Sep 1, 2004 | 10:34 AM
jimandmandy's Avatar
jimandmandy
I think you are confusing GVWR and GCWR, they are two different things. Carefully read the towing part of your owners manual. GVWR is how much the fully loaded truck can weigh, not the trailer. GCWR is the total for the loaded truck and trailer combined. This figure should be around 12,000 lbs for your truck.
Jim
Big-Foot
Oct 5, 2014 12:03 AM
wingcat
6.7L Power Stroke Diesel
Feb 15, 2014 08:39 PM
ThirdsACharm
All Things Towing
Nov 12, 2012 07:22 AM
Oakland60
Nov 8, 2011 06:53 PM
Oakland60
2009 - 2014 F150
Nov 6, 2011 04:32 AM
