Clamped pipes stuck!
Old Aug 30, 2004 | 08:39 PM
Longneck's Avatar
Longneck
Is there any easy way to remove clamped pipes (not welded) from each other? I need to replace my muffler, don't have a welder, and don't want to pay a shop to do it for me - this leaves me clamping as my only option. My pipes are clamped to my muffler now, but I can't get them apart, anyone have any tricks?
Thanks,
Longneck
Old Aug 30, 2004 | 09:18 PM
thelonerangerxlt's Avatar
thelonerangerxlt
I use a sharp cold chisel and hammer. Split the muffler inlet/outlet and spray with WD-40; it should come right off.......
Old Aug 31, 2004 | 12:14 AM
gotdiesel's Avatar
gotdiesel
kick, scream, pry, yell, pound,cuss, beat,etc. just remember as with everything else. DONT EVER FORCE IT!!! just get a bigger hammer. good luck
Old Aug 31, 2004 | 08:48 AM
Longneck's Avatar
Longneck
Thanks, I'll try both methods when I get home.
Longneck
Old Aug 31, 2004 | 03:34 PM
kwanderi's Avatar
kwanderi
I just got out my sawzall and they dropped right off. A small extention/adapter will take the place of the small amount you lose.
Keith
Old Aug 31, 2004 | 10:07 PM
Longneck's Avatar
Longneck
Do I need to weld on the extension/adapter? If so, than I will need to stick to the chisel. I didn't get a chance to work on it today, had to paint the basement
Longneck
Old Sep 1, 2004 | 05:49 AM
lancer's Avatar
lancer
I agree with kwanderi. Buy an exstention that has the same diameter on one end as you stock pipe and an inside diameter the same size as stock pipe on the other. You'll just need one extra clamp. Even if you get your old muffler off with the chisel the pipe may be distorded also. This could make it hard to install the muffler. The sawsall way is also alot quicker!!
Old Sep 16, 2004 | 02:13 PM
gatesj's Avatar
gatesj
Of course the easiest way is with an oxyacetylene torch... Get that thing glowing nice and bright and just pull it right off...
