Sponsored by: Real Truck
Trailer Wiring Woes
Old Aug 30, 2004 | 03:56 PM
2000F250SD's Avatar
2000F250SD
Trailer Wiring Woes
Does anyone have a trailer wiring schematic. The previous rocket scientist that owned my truck failed to use the plug in option for trailer brakes and cut the harness up. SOOOOO now I need a copy of the schematic if anybody has one. Any help appreciated.
Old Aug 30, 2004 | 04:20 PM
wlihntr's Avatar
wlihntr
i can email you a copy from my 2001. i will send you an email then you have to email me back with you address
Old Aug 30, 2004 | 04:29 PM
FortyFords's Avatar
FortyFords
okay the schematic I have is for a 02
Blk - gnd
org-battery charge to trailer
yellow-lft turn
dark greenn-rght turn
bk/lg -reverse lamps
bn/wh- parking lamps
Do you need to know pin number for the back of the the 7 pin connector?
Rich
Old Aug 30, 2004 | 04:30 PM
FortyFords's Avatar
FortyFords
sorry wiltnr ,i was typing while you responded
Rich
Old Aug 30, 2004 | 04:34 PM
2000F250SD's Avatar
2000F250SD
What I am worried about is right out of the main wiring harness there are 4 wires that have been cut next to the brake booster. The colors are red, white, light blue and black. The truck has the 7 pin harness and the 2 relays and the fuses in place for the trailer tow package. I am just unsure of what they have done with the cut wires.
Old Aug 30, 2004 | 04:38 PM
FortyFords's Avatar
FortyFords
Those are not part of the trailer harness those are customer access wiresthat they left dead ended for the purpose of adding things and not having to run wires through the firewal
what is it your trying to hook up and get working?
these wire have shrink tubing on them right?
Rich
Old Aug 30, 2004 | 04:46 PM
wlihntr's Avatar
wlihntr
check your e-mail
Old Aug 30, 2004 | 04:51 PM
2000F250SD's Avatar
2000F250SD
2 have shrink tubing. The red one has been cut and the white one has a blue butt connector on it. That is what was throwing me. I guess they were using them for something.
Old Aug 30, 2004 | 04:54 PM
FortyFords's Avatar
FortyFords
Yes ,chk them for 12v ,tape them up tuck them out of the way .
chk your e-mail wilnr sent you something.
Rich
Old Aug 30, 2004 | 04:55 PM
2000F250SD's Avatar
2000F250SD
I have the correct Ford trailer harness that should have plugged in under the dash. I guess I can cut the end off of it since the other end under the dash is gone and hard wire it. The cut wires under the hood were the ones that were confusing me. I guess I can just match the wire colors, they should be the same once I cut the connector off.
Old Aug 30, 2004 | 04:58 PM
FortyFords's Avatar
FortyFords
Okay ,If you need anything let us know
Rich
Old Aug 30, 2004 | 05:01 PM
2000F250SD's Avatar
2000F250SD
You have been very helpful. Do you think that will work just cutting off the connector end and matching the wires, solder them and shrink tube them?
Old Aug 30, 2004 | 05:05 PM
2000F250SD's Avatar
2000F250SD
Is there a preferred place to mount the controller? Do you have a recommendation on the type or brand of controller?
Old Aug 30, 2004 | 05:41 PM
wlihntr's Avatar
wlihntr
tekonsha prodigy, mine is mounted right under the little cubby hole under the radio, works great
