Sponsored by: Real Truck
gears gears gears
Old Aug 29, 2004 | 08:44 PM
bunnycop's Avatar
bunnycop
gears gears gears
37" tires,2003 7.3 PSD,4" exhaust, tymar intake,diablo predator,,now which gears do i need to make it get up and go?????? i have 3.73s(stock) now and it seems kinda sluggish...
Old Aug 29, 2004 | 09:52 PM
99f350sd's Avatar
99f350sd
Those are big tires I would say the 4.56's
Old Aug 29, 2004 | 09:59 PM
joe blow's Avatar
joe blow
I have a similiar setup. '04 F250 6.0 PSD with 37's on 17's. I regeared to 4.56's. I raised my RPM range by approximately 500 RPM. It rarely searches for the passing gear. The truck motors right along in overdrive everywhere I go and if I really stomp it, it goes into passing gear. I personally think it is a "tad" too low for daily driving. I am planning to go with 39's once these 37's wear out, which should put me @ the RPM I want to be. LONG STORY SHORT.......................4.56's are a good choice, ESPECIALLY if you want to tow ANYTHING!!!!!! Just my opinion.
Old Aug 29, 2004 | 10:55 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I third the recommendation for 4.56's.
Old Aug 30, 2004 | 04:27 AM
569104's Avatar
569104
And I fourth the recommendation of 4.56's....and while your in there how about a selectable locker or stronger limited slip.
Old Aug 30, 2004 | 08:08 AM
bunnycop's Avatar
bunnycop
thanks for the input, i wasnt sure if 456's would give me too much torque..thanks again...
Old Aug 30, 2004 | 06:24 PM
DCSpecial's Avatar
DCSpecial
I'll be a little different and recommend 4.10-4.30s with the 7.3 PSD. 4.30s would be close to the same effective gear ratio with 37s at a stock truck with 31.6" tires and 3.73s would be.
