5.0 computer dx3?
Old Aug 30, 2004 | 03:55 PM
dapozer's Avatar
dapozer
5.0 computer dx3?
Could someone please tell me what this is out of, year, ho or not, speed density or maf?
cal code is dx3 it also has e7sf-12a650-xid on it as well as sfi-sd3 eec-iv.
anyone?
Old Aug 30, 2004 | 05:36 PM
ncranchero's Avatar
ncranchero
Well, E7SF- indicates it was originally used on an '87 Thunderbird. The suffix -XID or X1D I cant locate. I have some more reference material if I can find it......
Old Aug 30, 2004 | 05:47 PM
ncranchero's Avatar
ncranchero
OK, the DX3 is a 5.0 Mustang. Here's the link to excellent EFI info.
http://fordfuelinjection.com/index.htm
Old Aug 30, 2004 | 06:27 PM
dapozer's Avatar
dapozer
I have checked the fordfuelinj site to find out that it should be a mustang, I also called ford and the said thunderbird as well but that was all the info they had. so I guess it is a speed density computer, and possibly a ho motor for a supped up t-bird?
Old Aug 30, 2004 | 06:47 PM
ncranchero's Avatar
ncranchero
I can check with my Ford guy tomorrow and see what he says. Looks like a Ford dealer should be able to ID it.
Old Aug 30, 2004 | 08:47 PM
dapozer's Avatar
dapozer
cool that will be a huge help. Also see if he knows the difference in cams between a 87 ho mustang and a 86 grand marque 5.0. I already have all the ho top end but the cam is the last peice.
s
Old Aug 31, 2004 | 03:49 AM
ncranchero's Avatar
ncranchero
Completely different animal as a 5.0 HO's firing order is the same as a 351, as well as a different spec.
Old Aug 31, 2004 | 05:47 PM
ncranchero's Avatar
ncranchero
No definate answer yet from my Ford guy but he's still trying when he has time.
The 86 Grand Marquis 302, it is a roller motor right?
Old Aug 31, 2004 | 06:37 PM
dapozer's Avatar
dapozer
OK here is the story: I have run this 86 garnd marq motor for three years and it needs more power and better fuel econ, It has over 120,000 on it. I have been able to get some e7 heads, a ho intake from a stang, the throttle body and egr from a markvii ( the throttle body has a part number of 5.0sho on it), and the computer from the mark also, so i figure a 5.0ho ( i will try to find manifacturing date tommorow). what i want to do is put the new stuff on it and have the equivlent of a 87 mustang ho. What do you think and what do i need to do? This is in a non emission truck with shortie headers.
shawn
Old Sep 5, 2004 | 05:25 PM
ncranchero's Avatar
ncranchero
No further info on the EEC I guess. Was the Mark VII motor junk or what? It IS the same as a Stang 5.0 HO you know. If your computer came from the Mark it will be good to go for your conversion ... as I understand it. 88 up Marks are mass air.
Old Sep 5, 2004 | 11:21 PM
dapozer's Avatar
dapozer
The motor seem to be good, I was just 10 min late to finding it. I was searching thru the local pnp and heard yelling a row away. some guy found this motor before i could get it. The did leave to computer, intake (upper), throttle body and egr, but took the rest. Now i have everthing to do the swap but the cam. What do you know about cams for this swap? I have heard i cannot use a replacement cam due to piston valving (?). I think i have flat pistons in the 86 marquis motor.?
shawn
Old Sep 6, 2004 | 04:56 AM
ncranchero's Avatar
ncranchero
That's the story of my life, a day late or dollar short!
Piston valving??????????
Old Sep 6, 2004 | 11:03 AM
dapozer's Avatar
dapozer
I read somewhere that i need to find a cam from a 86 up mustang or mark 7. and cannot go wiyh a ford motor sport or aftermarket cam due to flat top piston ( which i don't know if i have) mustang and ho pistons have valving top type (?) instead of flat tops i guess. I found this info on a town car 50 to ho site. and i am assuming i have the same 50 as a town car would have run in 86. Thoughts?
shawn
FoxClubNiner
Apr 29, 2016 06:50 AM
Big-Foot
Testing.....
Feb 25, 2016 11:04 PM
51M1
36
Oct 14, 2014 10:09 PM
zx250
Vendor Specials, Discounts, Product Announcements & Group Buys
Sep 30, 2012 01:22 AM
s2gots
All Things Towing
Sep 17, 2007 12:28 AM
