trans temp
Old Aug 29, 2004 | 10:14 PM
78_ford_F150's Avatar
78_ford_F150
trans temp
where do i put the prod for the sencer on the trans
Old Aug 29, 2004 | 11:47 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Some people put it in the pan, others put it in the test port, and still others put it on the fluid output line from the trans to the cooler. Ask any 3 people and you'll probably get 3 different answers as to which is the best way...
Old Aug 30, 2004 | 01:44 AM
94F150-408's Avatar
94F150-408
SoCals right, I've used both the test port and the output line from the cooler. I've also seen mention of a sensor installed both before and after the cooler with a dash mounted switch to toggle between the two. This is for those that want even more stuff to fiddle with, humm, maybe...
Trans50
New Member Introductions
Nov 20, 2013 02:09 PM
minishtr
Feb 27, 2004 06:54 AM
Jermafenser
Jul 10, 2002 11:29 PM
garyh
All Things Towing
May 28, 2002 07:20 PM
Maniak
Aug 31, 1999 08:05 AM
