1978 - 1996 Big Bronco
wont go into 5th or Reverse
Old Aug 29, 2004 | 12:46 AM
dyarumian's Avatar
dyarumian
I have a 5 speed mazda tranny and lately there is a lot of play in the shifter when it is in gear, i was driving on the highway today it it wouldnt shift into 5th, then i pulled into a parking spot and i couldnt get in in reverse to back out. what happened how can i fix it?
Old Aug 29, 2004 | 12:50 AM
JBronco's Avatar
JBronco
5th and reverse are both on one rod from the shifter, which sounds like it needs adjusting. See the following thread for instructions on how to adjust your shifter linkage (unless the Mazda is a cable shift).
https://www.ford-trucks.com/forums/s...d.php?t=276403
Old Aug 29, 2004 | 08:57 AM
BOJOFASO's Avatar
BOJOFASO
hey j i thought the mazda trans was an internal shifter type trans . if this is the case there is a small plastic bushing that goes on the shift handle dogs. to access this you must remove the shifter plate and you will see what i mean.
Old Aug 29, 2004 | 03:16 PM
JBronco's Avatar
JBronco
Like I said, I am not sure about the Mazda tranny. It may be.
Old Aug 29, 2004 | 03:41 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Same thing happened too my brother's ranger, the bushing fell apart and it got jamed in one gear, we dropped the tranny and pulled the plate, and found peices of the bushing in the tranny.
Old Aug 29, 2004 | 05:09 PM
JBronco's Avatar
JBronco
Sounds like the tranny is not very heavy duty for a full size truck like a Bronco. What years had this tranny? I had a five speed in a 1988 Ranger 4 cylinder - was that the same tranny as this?
Old Aug 30, 2004 | 03:29 PM
dyarumian's Avatar
dyarumian
so your saying that i have to drop the tranny just to see whats wrong. Im here at college and all i brought for tools is my 50 piece craftsmen set. SOme mechanic bach home but one in this january. thats way too early for it to go again. mabye i should give him a call.
Old Aug 30, 2004 | 04:37 PM
dhepler's Avatar
dhepler
Mazda tranny
That tranny is a toploader no adjustments. Sounds like the bushing has gone south. Either replace it with a Hurst billet or pm me and i will give you a good deal on the top end
Old Aug 30, 2004 | 06:39 PM
BOJOFASO's Avatar
BOJOFASO
no you dont have to remove the trans. you need to go inside the vehichle and remove the shift boot and then you will see how to unbolt the shifter and pull the shift arm out. once your in there youll understand it a little better.
get yourself a repair manual it is necessary and will help you to understand a little better.
Old Aug 30, 2004 | 08:56 PM
dyarumian's Avatar
dyarumian
is this the one:
530-391-5025 1988-96 F-150 4.9L/5.0L $199.99
Hurst equipted bronco
Old Aug 31, 2004 | 07:52 PM
BOJOFASO's Avatar
BOJOFASO
well if you would rather buy a shifter then more power to you but im a cheapskate and id rather buy the nylon bushing for under ten dollars.
Old Sep 1, 2004 | 08:05 AM
dyarumian's Avatar
dyarumian
I might work on it this afternoon, so far i have the boot off and all hayes tells is how to take off the lever does anyone know what to do after How many bolts where they are etc.. and then how to replace the bushing, anything would help
Old Sep 3, 2004 | 11:49 PM
GypsyR's Avatar
GypsyR
It's been a while since I did this so I might forget something. I took the boot loose and pulled it up. There should be another piece of insulation or something there to pull out, sometimes missing. Then you will see 3 torx head bolts. Put the shifter in 2nd or 4th and get the forward one. Then put the shifter in 1st or 3rd and get the other two. Now you should be able to pull that round cover up and then pull the shifter. You should see the plastic bushings(or their remains) and a couple of very thin metal washers where the shifter seats in. These you replace with your finger and reinstall the shifter.
Not rocket science, you should have little trouble.
Note: before reninstalling the shifter is an excellent time to change the trans fluid. You can refill it by dumping the ATF straight into the shifter hole instead of trying to pump it sideways into the filler hole. You might need an assistant to watch for ATF spilling out the "level hole" as you can't see it from inside the cab.
Old Sep 4, 2004 | 09:30 AM
BOJOFASO's Avatar
BOJOFASO
gypsyr has summed up the whole process and i have to say he left nothing out. if you follow these instructions you will have no problems. just put the trans in nuetrol before you remove the shifter.good luck and work safe so when you are done you can enjoy your labor.and let us know how you make out.
Old Oct 4, 2004 | 06:52 PM
Campdgreek's Avatar
Campdgreek
Same problem, different cause?
Hey fellas, I had pretty much the same thing happen to me that happened Dyarumian. I have an 88 f-150 4x2 with the Mazda tranny . I pulled the shifter off and noticed that of the two pins that locate the ball grooves under the cap, the left one is worn pretty badly, in fact it keeps popping out the the left side of the housing and causing lots of play in the shift. i plan on replacing the plastic bushing you speak of but can I replace this pin or will I have to replace the whole top?
fordka
Aug 2, 2014 10:02 PM
akaero
Sep 26, 2010 05:22 PM
Jimmy Mac
May 25, 2009 07:37 PM
theFabulousmisterG
1983 - 2012 Ranger & B-Series
Nov 15, 2007 07:38 PM
