Sponsored by: Innova
help with speaker install
Old Aug 28, 2004 | 09:44 PM
czdaryle's Avatar
czdaryle
I'm thinking of replacing the speakers in my 2003 f150. 2 questions.
1) does anyone know what the stock speakers are as far as quailty
2) How do you take off the interior door panels for the front and back doors.
I have an supercab
Thanks in advance
Old Aug 29, 2004 | 07:42 AM
prcrboy's Avatar
prcrboy
Quality depends on trim level and radio type. Is it premium, audiophile, or mach?
Also, the door panels-
1. reemoval for front door.
2. Remove the front door trim moulding.
3. Note:
Use the notch to remove the component.
Remove the interior door handle finish panel.
4. If equipped, remove the window regulator switch plate (14524).
1 Lift the front of the window regulator switch plate.
2 Disconnect the electrical connectors.
5. If equipped, remove the window regulator handle (23342).
1 Separate the handle cover from the handle.
2 Remove the screw.
3 Remove the window regulator handle.
4 Remove the spacer.
6. CAUTION:
Do not pull directly outward on the front door trim panel, as damage
may occur.
Remove the front door trim panel.
1 Remove the screws.
2 Lift and remove the front door trim panel
7. If equipped, twist the courtesy lamp bulb socket one quarter turn and remove the socket from the front door trim panel.
8. To install, reverse the removal procedure.
rear
1. Remove the rear door window latch screws.
2. Remove the rear door window garnish panel.
3. CAUTION:
Do not pull directly outward on the rear door trim panel, as damage may
occur.
Remove the rear door trim panel.
2 Remove the nut.
3 Remove the pin-type retainer.
4. Lift and remove the rear door trim panel.
5. To install, reverse the removal procedure.
Old Sep 3, 2004 | 06:12 PM
tinman67's Avatar
tinman67
www.crutchfield .com is a very informative place to go to find out what speakers to fit in your vehicle and if you buy speakers from them they will send a very detailed set of instructions on door panel removal for your vehicle free of charge.
curtainrod
Aug 11, 2014 03:49 PM
JCastellaw
1966 - 1977 Early Broncos
Sep 2, 2008 11:17 AM
97rangerguy
Dec 7, 2004 05:17 PM
FordPickMeUp
May 20, 2004 07:06 AM
greymule
Oct 11, 2002 01:42 PM
