Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Epoxy flooring
Old Aug 28, 2004 | 08:23 PM
fnx4wheeler's Avatar
fnx4wheeler
Question Epoxy flooring
I'm going to put epoxy flooring on my garage floor (currently concrete). I've heard the kit that Home Depot sells sucks. It sounds like this is one item that a more expensive material from a specialty shop is worth it. Anyone have first hand experiance with this?
Thx
fnx4wheeler
Old Aug 29, 2004 | 12:51 PM
numbersix's Avatar
numbersix
Check out:
http://www.stonhard.com/
This is what they use to cover the floors in Kraft plants. It's tough. It stands up to being wet, forktruck traffic, dropping stainless steel parts on it, etc.
Old Aug 29, 2004 | 10:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
That looks like real high dollar stuff!
There are some other threads here on shop floor coatings you might want to check out.
Old Aug 30, 2004 | 07:01 AM
broncobob's Avatar
broncobob
The Stonhard stuff is pretty expensive, and has a couple of drawbacks in garage use. If you park a vehicle in the same spot for a long time, and you have used a light color Stonhard, the tires will leave yellow stains that are about impossible to remove. Also, if you trowel it out nice and smooth so it looks nice, it tends to be a bit slippery when wet. We used a lot of this at a factory I worked at, held up good for fork lift traffic and such. One of the contractors who put it down appropriated the left over material and did his garage floor. Really looked nice, till his wife came home one day during a rainstorm and pulled in to the garage a little fast. Kinda messed up the front of the car, didn't do the garage any favors either.
Old Aug 30, 2004 | 08:20 AM
teamptg's Avatar
teamptg
Thx
fnx4wheeler
the best epoxy floor is the chip system with the granite look. first clean your floor with tsp on the greasy spots then etch the whole floor with murietic acid and water 1to4. rinse and spread baking soda all over the floor agitate with a broom then rinse again. let dry 2 days or so completely dry. apply bae coat color 2 part epoxy then spread chips in it you can walk on the wet epoxy with golf shoes. next day broom off excess chips and apply epoxy clear coat. next day final clear coat and you will have the most beautiful garage floor that isn't slippery. good luck material cost 2 car garage approx. $700 to $800
Old Aug 30, 2004 | 02:36 PM
fnx4wheeler
teamptg,
I appreciate the info, Do u recommend a specific brand? Also, best place to buy it?
thnx
fnx4wheeler
Old Aug 30, 2004 | 03:06 PM
teamptg's Avatar
teamptg
Talking epoxy floor
life deck makes a good chip and clear. the 2 part color first coat is a little tough to apply. I use ellis corp 400fd base coat throw the life chips in it and clear with the life clear. I buy all my products from altura paint in vista ca. the life base coat sets up quick and you have to mix it pour it out of the bucket and then spread it around or it will turn to jello in your bucket.
Old Aug 30, 2004 | 04:01 PM
ford390gashog's Avatar
ford390gashog
this is the best system and rust oleum makes a pretty good one i have had ver good luck so far it stands up well and it costs about 400.00 to do a 3 car garage
Old Aug 30, 2004 | 06:44 PM
teamptg's Avatar
teamptg
gashog
Please ask truck tech questions in the proper tech forum -Admin
Old Dec 11, 2022 | 07:16 AM
JWA's Avatar
JWA
Originally Posted by pmhip
o response to this
Due probably because there's little experience or little interest?
Old Dec 12, 2022 | 05:50 AM
JWA's Avatar
JWA
@JWA you say that. this is my job
Okays and so what? If this or the topic is in your area of expertise you should be able to provide a huge amount of useful information.
Steve Bennett
Garage & Workshop
18
Dec 7, 2022 06:49 PM
nut1605
Garage & Workshop
Jan 7, 2008 11:38 PM
4.9inline6
Garage & Workshop
Jul 3, 2006 12:22 PM
GotLift
Garage & Workshop
Oct 16, 2005 07:36 PM
Primered86XLT
Garage & Workshop
15
Feb 3, 2005 11:55 PM
