Power Steering
Old Aug 28, 2004 | 09:56 AM
Shelstin's Avatar
Shelstin
Power Steering
A question was asked on another thread about adding PS without spending a bundle. I am sure that some of you have done that. I am trying to build this truck so my daughter can drive it some in a year or so, and there is no way that she can drive it as it will be. Any ideas on inexpensive ways to handle this? Like I said earlier, I am probably going to ask a lot of questions here.
Thanks, Rick
1960 F250 4x4
Old Aug 29, 2004 | 01:20 AM
Col Flashman's Avatar
Col Flashman
Thumbs up
Shelstin
Go here; http://www.johnsf100.com contact John & tell him I sent you, he can supply the original straight bolt on Ford type Master Guide P/S system that was an Option for our Orphan Year trucks.
Cheers
Colonel Flashman
Red '58 M-100
Blue '58 M-100 Panel
Thanks, Rick
1960 F250 4x4
Old Aug 29, 2004 | 08:30 AM
wosborn's Avatar
wosborn
Search this forum for "power steering"
One hint: Toyota
Old Aug 29, 2004 | 10:16 AM
mr4speedford's Avatar
mr4speedford
Guy's, since Rick has a 4x4, will the toyota work? Could he just swap a latter model 4x4 axle from a mid 70's ford with 4wd? I'm sure spring mounts would need to be changed and steering box etc. Just throwing some other idea's out. -4speed
Old Aug 29, 2004 | 05:53 PM
Col Flashman
speed
Not unless he wants to do a lot of cutting & welding to install the T@^*%a system.
It'd probably be easier to install the mid '70s sytem, IF he chooses not to go w/ the Ford type system I suggested that was designed to be installed in his truck.
Flashy
Old Aug 30, 2004 | 04:04 PM
Shelstin's Avatar
Shelstin
As expensive as this is already getting, it looks like it is going to be fiberglass bondo for the rusted cab parts, no power steering, and a spray cans of primer and red paint from WalMart!
Old Aug 30, 2004 | 07:39 PM
A187inTheSuburbs's Avatar
A187inTheSuburbs
walmart paint booo... im extremely cheap with my truck but i would recommend zero rust. It comes in aerosel cans and is a great primer
Old Aug 30, 2004 | 09:31 PM
Shelstin's Avatar
Shelstin
Yeah...I was joking about the wall mart spray paint....I think!
