A/C basics
Old Aug 27, 2004 | 03:00 PM
dino360's Avatar
dino360
Angry A/C basics
I was searching the forums and after reading through hundreds of posts, I am a litttle confused. I read that the low side should read mid 30's to low 40's and high side should read between 225-250 depending on ambient temperature. If the low side reads high while the compressor is running at max a/c does this indicate too much fluid or lack of. If the high side reads high or low what does this indicate? How does the high side pressure reading depend on ambient temperature (higher outside temperature higher pressure reading?)?
Old Aug 27, 2004 | 08:57 PM
Pikachu's Avatar
Pikachu
The higher the low side pressure, the more refrigerant in the system, and the higher the temperature of the evaporator. In other words, the an undercharged system will actually produce colder temperatures, but is more likely to ice the coils. The whole thing is a balancing act.
The high side pressures will increase as the ambient temperature increases. A basic rule of thumb is 2.2 times the ambient temperature for the pressure, but it isn't set in stone. If the high side reads high, it usually indicates lack of cooling across the condensor coils. If the low side reads high, it can indicate overcharge, or flow restriction in the system. Ideally, if you can get the evaporator down to 34F and keep the compressor from cycling on and off, that's perfect. It doesn't happen often, though.
Old Sep 5, 2004 | 12:07 PM
tinman67's Avatar
tinman67
Engine rpm can also change pressures as the compressor sppeds up and slows a bit this is why it has the pressure switches and clutch etc. Under higher rpm the high side can rise a bit and the low side can drop a bit also pressures are different for r-12 and r-134
JockD
Dec 18, 2023 07:46 PM
02expy
Jun 29, 2016 03:52 PM
mizzleman
Jul 13, 2015 04:07 PM
Ron1999
1997 - 2003 F150
Jul 1, 2015 12:19 PM
tonyrcl
Jul 26, 2009 03:05 PM
