The switches have a ground lug because of the different covers that can be used with the switches. If you use a metal switch box cover, according to NEC, the cover must be grounded. The switch acts as part of the grounding path when the cover is screwed to it.
This was off the top of my head. I will assume no liability in this! Use the info at your own peril!!
