Please Help!!
Old Aug 26, 2004 | 02:11 PM
orockaway's Avatar
orockaway
Unhappy Please Help!!
I have a 97 expo..... my truck wont start.. i hear a click when i turn key... i have check the battery and the terminals.. they are ok.. i have checked the starter. the starter soleniod has 3 connections, 2 of the connections look like they connect to battery cables, the starter has a very short "rope looking" wire that looks as if it was connected to 3rd connector on soleniod. it is decomposed and corroded. is that a ground that comes out the side of the starter? can that be replaced without buy a new starter? please help?
<!-- / message -->
Old Aug 26, 2004 | 02:35 PM
CampingFamily's Avatar
CampingFamily
decomposed and corroded ..... still connected?
If so, may not be the problem.
Starter out and to Autozone for testing.
Or... If you have an external solenoid block, easy to replace and not that expensive.
Battery Terminals clean?
Old Aug 26, 2004 | 03:42 PM
orockaway's Avatar
orockaway
i do have an external solenoid block, but there is a small coil that comes out of the starter is not connected to 3rd terminal on soleniod block.... i do hear a click and all dome lights and radio go out when i turn the key. wont start.
Old Aug 27, 2004 | 07:23 AM
joed_6's Avatar
joed_6
did you have the battery tested? wife has a 97 same exact things you describe, battery was the cause
jahollis2380
13
Jun 22, 2010 07:35 PM
IZZYAZ
Electrical Systems/Wiring
Apr 29, 2009 02:19 PM
IZZYAZ
Apr 29, 2009 08:17 AM
cshook1
May 30, 2005 06:24 PM
merlin4044
1983 - 2012 Ranger & B-Series
27
Oct 29, 2003 07:28 AM
