Fuel Cap Replacement
Old Aug 25, 2004 | 08:12 AM
CANNON2002's Avatar
CANNON2002
My wife lost the fuel cap on our 97 Expedition. Went to Autozone, bought an aftermarket cap and since then the Check Engine Light has been on. The fuel vapor code is on, had Autozone clear code twice after purchasing aftermarket cap and the check engine light still comes back on. I was told that the after market caps don't have the correct vapor spec's causing check engine light to come on and that I should purchase one from Ford dealership. Anyone heard of this before?
Old Aug 25, 2004 | 08:53 AM
turbo TED's Avatar
turbo TED
The cap could just be defective I would take the cap back to the store & explain what
started to happen after you bought their cap, & just ask them to replace it.
LIVE LONG AND PROSPER. .TURBO TED
Old Aug 25, 2004 | 11:02 AM
mapman's Avatar
mapman
You are correct about cap replacement. I had a gmc yucon and replaced mine with aftermarkret cap also. It kept turning the se light on till I replaced it with factory gas cap. My mechanic told me later most aftermarket caps do that.
Old Aug 25, 2004 | 12:16 PM
CANNON2002's Avatar
CANNON2002
I'm on my second aftermarket fuel cap and the check engine light is still on. I also thought maybe the first was defective and had it replaced. I will try a Ford cap next. Hopefully that will fix the problem. Thanks for your replies!
norman2012
3.0L Powerstroke Diesel
Nov 27, 2016 10:30 AM
fasthauler
16
Sep 29, 2016 08:56 AM
BogginDave
Dec 17, 2015 07:28 PM
TheRedBeast01
Modular V10 (6.8l)
Jun 30, 2014 11:09 AM
Stangfire
1997 - 2003 F150
Apr 29, 2008 08:51 AM
