Rear leaf spring bracket replacement 1995 350
Old Aug 24, 2004 | 12:48 PM
black460's Avatar
black460
for the rear leaf spring brackets....
i know the front bracket is bolted to the chasis. is the rear bracket bolted or mounted with rivets?
its rusted so bad i cant tell if its bolted or riveted...not good.
ford couldnt tell me either...go figure.
Old Aug 24, 2004 | 07:08 PM
quicklook2's Avatar
quicklook2
the shackle is boted to a bracket that is riveted on the frame. i hope that explains it. you will have to grind them off. i had to grind bolts off shackle also. you have to buy everything at ford.
Old Aug 25, 2004 | 07:23 AM
black460's Avatar
black460
does the bracket need to be riveted back on the frame or can it be bolted back up? i dont have any tools for rivets that large.
Old Aug 25, 2004 | 10:11 AM
quicklook2's Avatar
quicklook2
i would use self locking bolts/nuts
Old Nov 7, 2006 | 06:58 AM
edwars2's Avatar
edwars2
Can some one tell me where I can purchase a new bracket? Is this a part you can only get new from the FOrd dealer or will most auto part stores carry it?
For a 1993 Ford Ranger
Old Nov 7, 2006 | 08:31 AM
quicklook2's Avatar
quicklook2
ford part but national parts depot carries them.
go to column on left and hit the link.
fordford1
Jul 26, 2012 09:53 PM
Chopper-Boyz
1983 - 2012 Ranger & B-Series
31
Nov 28, 2010 05:41 PM
doesntmatter
Aug 31, 2010 11:50 AM
Boba Fett
Jan 2, 2010 08:46 AM
WesternAuto17
1978 - 1996 Big Bronco
Oct 17, 2003 10:48 PM
