Bronco II Ford Bronco II
Got a new code reader!
Old Aug 24, 2004 | 10:55 AM
CryHavoc's Avatar
CryHavoc
Well I have been looking at code readers on Ebay and at auto parts stores. The Actron one is 30 bucks in stores and about half that on Ebay but I found an awesome digital display code reader (no trying to count blinking lights) at Checker Auto (same as Kragen) for only $35.00!!
This is the one I got: http://www.iequus.com/item.asp?cid=10&pid=3145
Old Aug 24, 2004 | 11:42 AM
87 XLT's Avatar
87 XLT
SOunds pretty good. Now that you have the scanner & the shop manual all you need is the EVTM & you will be all set to fix just about anything that goes wrong with your B-2.
Old Aug 24, 2004 | 11:50 AM
CryHavoc's Avatar
CryHavoc
EVTM? What is that?
See that is why I like my old '53, just a timing gun and vacuum gauge and I am pretty much set!
Old Aug 24, 2004 | 12:00 PM
87 XLT's Avatar
87 XLT
Electrical & vacuum troubleshooting manual, about 20 bucks at www.helminc.com It will have wiring diagrams for all the different circuits on your B-2 & tips for how to troubleshoot & repair them. Fuel pump not running or cruise control not working etc etc. The EVTM will tell you how to fix them.
Old Aug 24, 2004 | 12:14 PM
CryHavoc's Avatar
CryHavoc
well I just have one prolem now. I can not find the connector to plug in the tester. Any ideas?
Old Aug 24, 2004 | 12:28 PM
87 XLT's Avatar
87 XLT
Should be under the hood, passenger side somewhere between the air filter box & heater blower housing.
Old Aug 24, 2004 | 12:55 PM
CryHavoc's Avatar
CryHavoc
Thanks. I found it. It was capped off and kinda dirty.
Everything checked out fine except for a code 67c (Air conditioning compressor clutch switch fault)
On the KOER test I got an all clear (code 11)
So the fast idle must just be the air control valve like you said.
Old Aug 24, 2004 | 01:26 PM
87 XLT's Avatar
87 XLT
Yeah clean the IAC & see how it does.
Old Aug 27, 2004 | 12:12 PM
jclopezv's Avatar
jclopezv
Cryhavoc, Thank you for the Tip, I just order the Code reader, It was 35.49 and 8.50 s&h. I hope it will find why the idle is irregular when the engine is cold.
JC
Old Aug 27, 2004 | 12:18 PM
CryHavoc's Avatar
CryHavoc
Actually I took apart the air control valve like was suggested, let it soak a few hours in parts cleaner (not the electrical part) blew it out and reassembled it, and everything is fine now!
Old Aug 27, 2004 | 01:05 PM
87 XLT's Avatar
87 XLT
Good deal, glad to hear that did the trick. BTW, my first car was a VERY used 53 Chevy. My dads reaction when he saw it was "Youpaid 150 bucks for THAT?" But with a fresh coat of paint rechromed bumpers & grill & a set of seat covers, I turned it into a very nice little car. What are they worth today in primo condition? Wish I still had that car. As you say working on the 53 was a whole different ball game compared to the newer ones.
Old Sep 4, 2004 | 07:07 AM
jclopezv's Avatar
jclopezv
Guys, I got the Code Reader; It comes with a nice and very clear manual. I follow all the instructions I even read the whole thing before do any testing. note: i did it koeo I got the follow:
15 : KOEO : Read Only Memory test failed
10 : "separation code:
32 continuos memory: EGR pressure feedback fault.
Then I followed the code reader troubleshooting guide w/out any success. something funny about that was that when I routed a jumper wire from the single pin test connector to the battery negative post, i did not hear any "clicking" or any noise indicating that the auto-test was being performed. (i repeat the procedure 3 times:
-I drove the car for a couple of minutes.
-koeo-code reader testing: 15 (o),10,32 (c)
-drove the car again.
-clean all the connectors, koeo, code reader testing with the single pin jumped to the battery (-). no codes (only 000), no clicking no noises.
-drove it again.
-koeo (connecting the single test pin into the code reader) : 15,10,32. again and again and again.
Any ideas?
Thank you.
Old Sep 4, 2004 | 10:42 AM
mrshorty's Avatar
mrshorty
Not sure about those instructions. What test is supposed to be performed by connecting the STI (single wire) to ground instead of STO? I don't knwo of any test that is performed that way.
Ken00 has posted a set of instructions for the self-tests in the tech info post. Check the instructions that came with your code reader against those. There's also a good set of instructions at www.dalidesign.com/hbook/eectest.html This latter link doesn't talk about using a code reader, but the test procedures are the same, and the hook up is similar.
Old Sep 14, 2004 | 11:26 PM
dino360's Avatar
dino360
Angry
I also ordered one and am looking forward to using it.
