Replace parking brake cable (w/o tension equalizer)
Old Aug 24, 2004 | 12:32 AM
nickmont222's Avatar
nickmont222
Question Replace parking brake cable (w/o tension equalizer)
Seeking instructions on how to reconnect the front parking brake cable to the mid-ship cable on a 1993 F150 w/o a tension equalizer. I replaced the broken front cable, but can't figure out how to get the slack necessary to connect the front to mid-ship cables. I looked for instructions in my Chiltons manual, but it only provides instructions using a tension equalizer, which my truck does not have. Thanks.
Old Aug 24, 2004 | 09:46 AM
ssn randy's Avatar
ssn randy
its difficult, you have to pull the slack. I've done it before and normally it takes two people to pull on each side meeting in the middle
Old Aug 24, 2004 | 07:43 PM
nickmont222
txs
Txs Randy... I will attempt to struggle with it tonight. It appears the handle/spool mechanism has a white plastic tab that, if I could figure out how to remove it, would allow the spool to over-rotate, which would provide slack in the cable. Not sure how to do this, however. It would make the connection simple.
Trojan8975
Oct 12, 2024 04:21 PM
tinman52
25
Jun 15, 2021 08:43 AM
hunter301
Nov 12, 2014 07:58 PM
curtis88
Feb 13, 2014 09:45 AM
JMattyAK
Feb 10, 2011 05:36 PM
