battery wire gauge
Old Aug 23, 2004 | 11:42 PM
GasMonkey's Avatar
GasMonkey
battery wire gauge
will a higher gauge battery wire do anything, better starting?
Old Aug 24, 2004 | 12:08 AM
200000+F150's Avatar
200000+F150
Depends on whether the current one is adequate or not. I see a lot of factory replacement cables that are 6ga. I think this is too small for anything, but especially a large V8 high compression. I'd recommend a minimum of 4ga. 2ga would be even better. I once had a Chevelle that I put #1/0 welding cable and a 1000cca battery on. Even w/11:1 compression it would spin right over.
Old Aug 25, 2004 | 05:55 PM
SgtJoe's Avatar
SgtJoe
Factory cables should be ok. If you're not sure if its factory, then try this. Watch the battery cable when you start the engine. I've seen cable flex when they're too small (or the engine was tight/seized). Just an idea.
If your starter spins the engine at a normal speed, don't worry about the cable.
filthy6
Apr 21, 2014 05:38 AM
damonlan
22
Jan 7, 2013 01:00 PM
berick
Jul 31, 2012 09:09 AM
Computermike
Nov 27, 2008 02:23 PM
Kijutsu
1997 - 2003 F150
Mar 23, 2007 08:07 PM
