vapor lock or fuel pump
Old Aug 23, 2004 | 05:04 PM
traderguy111's Avatar
traderguy111
I have a bronco with a 302 when the engine heats up it will start to sputter and die if I let it sit for an hour or so it will fire up and run fine until it gets hot again. I sound like its running out of gas. or vapor lock but I thought a fuel injected engine cant get vapor lock so im also thinking its the fuel pump in the tank. How can I test the fuel pump without taking it out of the tank or is it vapor lock? any suggestions? Thanks Dan
Old Aug 23, 2004 | 09:46 PM
LxMan1's Avatar
LxMan1
The last 2 vehicles that I had do this it turned out to be a bad pick-up coil in the distributor. It would sound really lean and even smell like it too, but it was actually losing fire, not fuel. After it sat for awhile, it would run great until it got hot again.
elkhunter
23
Jul 28, 2023 10:48 PM
Steves55
Dec 27, 2015 06:18 PM
Turtle Carton
Jun 27, 2014 10:58 AM
oscar_007
Jun 29, 2006 08:22 AM
redstone
1947 and Older Ford Trucks
Sep 20, 2002 05:05 PM
