97 explorer transfer case problem
Old Apr 8, 2000 | 01:24 PM
nj's Avatar
nj
I have a 97' with SOHC, electronic shift with control trac with 125000mi. It jumps out of hi range (skips a gear tooth and clunks) when transmission is put into reverse (fine in lo range) and has even jumped out of hi, and stayed in neutral, while travelling at highway speed (ouch). It seems as if the electronic motor does not turn far enough to fully engage the hi range gear (I have had the transfer case apart and could not find any problems with worn parts but I did notice that the aluminum spiral which moves the hi/lo gear inside was marked where the hi gears natural location was-I felt that the gear should have moved farther than this wear point indicated). I rotated the contacts on the electronic shift motor as far as possible (not very much)to allow more rotation which seemed to help for about a month but it now is back to the same problem. As far as I know there is no TSB. Any help out there?
Old Apr 9, 2000 | 08:36 AM
ddale's Avatar
ddale
sjwelds
Dec 3, 2014 10:42 AM
jimbob21rc
Dec 9, 2006 06:56 PM
buffalobob
Nov 20, 2005 12:15 PM
shandixie1
Feb 1, 2004 09:42 PM
wildjon300ci
Jun 15, 2001 07:21 PM
