rear main seal
Old Aug 23, 2004 | 01:12 PM
hster's Avatar
hster
rear main seal
Hi,
I am changing rear main seal on 1981 f 150 inline 6 w/ speed manual tranny. I pulled rear m. seal and there does not appear to be any wear or tear. It is rubber. Could it have shrunk over the years? Or perhaps lost its shape. i was losing 2-3 qts of oil per day
Your thoughts please
Old Aug 23, 2004 | 04:15 PM
85F_150driver's Avatar
85F_150driver
i would go ahead and put a new rear main in it. Put a new oil pan gasket while your at it. and might want to make sure you don't have a leak from the valve covers.
Old Aug 23, 2004 | 05:22 PM
Blasphemous's Avatar
Blasphemous
I'm in the same boat... I'm losing quarts a day. I got a new rear main seal, already changed the valve cover gasket and am picking up an oil pan gasket. How hard is it to replace? I'm very handy, just never done a rear main before. What tools will I need besides basic wrenches and sockets?
Old Aug 23, 2004 | 05:52 PM
Charles in AZ's Avatar
Charles in AZ
If your engine is like most of the 300 cid sixes I've seen, you will have to pull the transmission, bell housing and clutch and flywheel. This gives you access to the one-piece rear main seal. Remove and replace the seal and then replace all of the stuff you had to remove. The pan doesn't have to come off. Be sure that it's the seal that is leaking because replacing it is not an easy job. Good luck!
Old Aug 23, 2004 | 06:01 PM
Blasphemous
I'm more than positive that it's the main seal. It almost looks like it's leaking oil from the transmission. What should I use to pull the main seal? I have an automatic trans.
Old Aug 23, 2004 | 08:15 PM
Charles in AZ
Once you get to the rear main seal, you can remove it with a sharpened screw driver with a twenty degree bend on the last 1/2". Tap it under the metal lip of the seal and pry out. You do have to remove the transmission and flex plate on the AT equipped six; it has the one-piece seal as well. I recommend you rent a transmission jack for the job if you don't have one.
Old Aug 23, 2004 | 08:21 PM
Charles in AZ
Incidentally, quite often a badly leaking rear main seal is a symptom of loose main bearings. The increased motion of the crankshaft due to the increased bearing clearance will exceed the seal's ability to conform to the crankshaft. You may want to put an accurate oil pressure gage on your engine and check the pressure. If it is low, you may want to consider checking the mains especially if yours is a high mileage engine.
Old Aug 23, 2004 | 09:21 PM
Blasphemous
That'd be basically rebuilding the engine. I don't have time to do something like that right now. I'm just going to replace the seal and make a long trip. After that, I'll probably look into rebuilding the whole engine then.
Old Aug 24, 2004 | 04:02 PM
Blasphemous
I got half way through it today, what a pain in the ***! I don't think that tranny's been moved since in was installed in '84. The tranny cooler lines busted off, so, I'm just going to install rubber lines with bard fittings and clamps. Luckily, those were the only things that broke. I did gouge my knuckle damn near to the bone on the flywheel while removing it. That metal piece that goes between the block and flywheel is a nightmare. On another note, the rear main seal was destroyed. The metal wire was showing through all the way around and there was a couple of 1/4" sized chunks missing.
A lift and ALL my tools would make this much easier. I'm doing it on the ground with my basic hand tools... sockets, wrenches and screwdrivers. I don't have any extensions or anything fancy. All in all, I'd say it's a solid one day job... two days for a first timer. Manual trannies are so much easier!
Old Aug 25, 2004 | 03:16 PM
Blasphemous
I just finished the install of my new rear main. Went to start the truck and it's acting like the battery's dead. I tried to jump it, but the same symptom. I had the battery disconnected the whole time I was working on it. Could the starter be f'ed up? Could the battery be DEAD (un-rechargable dead)?
Old Aug 25, 2004 | 10:28 PM
Big ole Dog's Avatar
Big ole Dog
Is the battery grounded propley the the motor and frame
Old Aug 27, 2004 | 01:44 PM
85F_150driver
did you get it started yet? sounds weird but a day after i finished putting my new rear main and cluthc kit in my starter froze up. If it still acts like the battery is dead take it to an automotive store and have it tested. might also have the battery tested. if that doesnt get it goin let us know surely we can help ya get it going again.
Old Aug 27, 2004 | 02:31 PM
Blasphemous
I got 2 new batteries, so I know that wasn't it. The starter was turning the motor over, just not fast enough. It sounded VERY labored while turning over. Is that was your starter was doing also?
Old Aug 27, 2004 | 06:49 PM
85F_150driver
did that for about 2 months then it wouldnt even turn. so i was parking on hills for a few days till i had time to change the starter. autozone has a lifetime warrenty starter for like 46 dollars plus 30 dollar core. I would take the starter out and get it tested. most parts stores can test them for free.
Good Luck with it, Ben
Edit: how many cca is the battery you are useing?
Old Aug 27, 2004 | 06:53 PM
Blasphemous
Yep, that's next on my list of things to do.
