rear main seal
Old Aug 27, 2004 | 07:00 PM
85F_150driver's Avatar
85F_150driver
how many cca is the battery you are useing?
Old Aug 27, 2004 | 07:03 PM
Blasphemous's Avatar
Blasphemous
535cca, 630 ca
Old Aug 27, 2004 | 07:41 PM
85F_150driver
are your cables in good shape? I run a 800 ca 675 cca battery on mine. my advise would be to check the cables and get the starter tested.
Old Aug 27, 2004 | 08:07 PM
6.9tank's Avatar
6.9tank
ive had a lot of starter problems on the old trucks esp. when the rear main is leaking because of all the oil that runs into them and its hard on the electrical componets inside the starter id just replace or rebuild the starter
Titanic15
1978 - 1996 Big Bronco
Feb 12, 2014 11:34 PM
Bombshellbree
Jan 13, 2012 10:44 AM
halltm
Apr 13, 2011 10:25 PM
DT 466Man
Apr 29, 2005 10:41 PM
adroc104
Apr 3, 2003 08:27 PM
