Spark Plug Replacement
Old Aug 23, 2004 | 09:49 AM
jhchang's Avatar
jhchang
I'm fairly mechanically inclined, but never attempted to change spark plugs before. I have a 97 5.0 V8 and would like to know if there are any tips on changing plugs and wires. I noticed the spark plug locations are hard to reach and heard that entering through the wheel well works well. Any tips from someone who has done this procedure succesfully? Please advise.
JC
Old Aug 23, 2004 | 10:19 AM
99Xplr's Avatar
99Xplr
Granted I have the 4.0 SOHC not the V8, but the only way to get at some of the plugs on that motor was to go through the wheel wells. With the right extensions and universal attachments, I don't think I'll do any of them from the top next time. It's a lot easier on the back sitting on a stool in the wheel well then hanging over the motor.
Old Aug 23, 2004 | 11:19 AM
5.0EBExplorer96Snow's Avatar
5.0EBExplorer96Snow
The wheel wells are the best way change the plugs on a V8.
Old Oct 28, 2004 | 08:56 PM
photobob1's Avatar
photobob1
Do you remove the entire ridgid plastic wheel well covers? or just the flexible inside liner?
Old Oct 28, 2004 | 09:24 PM
5.0EBExplorer96Snow
Just the flexible liner.
Old Oct 28, 2004 | 09:45 PM
pax's Avatar
pax
Also buy a spark plug boot puller, it is a lot easier to pull the boot out with the puller. It is only a few dollars, well worth it.
Old Oct 31, 2004 | 12:18 AM
norrislaketn's Avatar
norrislaketn
change your wires at the same time
Old Jan 9, 2005 | 03:07 AM
1BadF150's Avatar
1BadF150
is he speaking of a mustang? i thought in 97 they already had the 4.6???
Old Jan 9, 2005 | 05:44 PM
maa139's Avatar
maa139
Don't forget the never seize on the plug threads and the tune up grease on the other end!
Old Jan 10, 2005 | 07:00 PM
mvoeller2's Avatar
mvoeller2
In response to 1BadF150, they used the 5.0 up until 01, then in 02 they went to the 4.6.
Old Jan 12, 2005 | 03:59 PM
1BadF150's Avatar
1BadF150
are you kidding?!?!?!? LOL 2 friends of mine have a 97 cobra 4.6L.... 2002? you gotta be joking...
Old Jan 12, 2005 | 04:04 PM
CobraXP's Avatar
CobraXP
Last year for the 5.0 in Mustangs was 95. 96 they went with the 4.6
That was the first year they played with 5.0's in the Explorers - left over parts from Mustang GT's, etc. They did not come out with V8 Explorers until 96 models.
96-01 Explorers were 5.0's. Then they went to the 4.6 in them after that...
Old Jan 12, 2005 | 04:06 PM
1BadF150's Avatar
1BadF150
thank you.... lol i knew it was either 97 or 96, but they went to the 4.6 way before the newer bodystyle...
Old Jan 12, 2005 | 04:08 PM
1BadF150's Avatar
1BadF150
so then in reference to the author of this thread... the first thing you need to do is go back to where u got your plugs and buy the right ones for it lol
Old Jan 12, 2005 | 04:17 PM
CobraXP's Avatar
CobraXP
I hope he has changed them since this thread started (if they needed changing). The thread was from August of '04...
But on the track of the thread - the easiest way to change the plugs is through the fenderwells. Jack it up, remove the front tires, and look for a flap that is held in the fenderwell by pushpins. Remove those and the flap, and you are staring at the plugs and wires. Same for V6's, V8's, and Rangers...
