pinging/preignition 93 4.0 advice
Old Aug 23, 2004 | 07:12 AM
ksvtwin's Avatar
ksvtwin
Hello, i just recently purchased a '93 ranger with 4.0 v6. it is a 4wheel drive and i love the truck. it only has 76,000 miles on it and is in great shape. only problem is it rattles bad when you want to accelerate up a hill. I put premium fuel in it and that helped a lot but it still does it and premium is expensive. does anyone have any advice on how to make this quit? i bought some new spark plugs and i'll install them tonight but any other advice would be very much appreciated. thanks, Kent
Old Aug 23, 2004 | 08:41 AM
D-ranged2.5's Avatar
D-ranged2.5
pinging
I had been having really bad engine problems (pinging, lack of power, rough idle and the like) and once I changed the plugs, things improved dramatically. Check your manual b/c mine actually says that pinging is to be expected. I have the 2.5 though in an 01... either way, good luck!
Old Aug 23, 2004 | 01:02 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
There are three things that typically cause the 4.0L to ping (in no particular order):
1) Dirty MAF sensor.
2) Loose lower intake bolts causeing a vac leak.
3) Engine needs to be decarboned.
If you look in the sticky titled technical information, you will find help on how to address these. For #2, get a service manual and simply retorque the bolts in the correct sequence. BTW, there is a TSB that addresses #3; it specifically advises against using anything other than 87 octane as that can result in carbon buildup. All three items above are rather simple to implement. Let us know how you come out.
Old Aug 24, 2004 | 07:09 AM
ksvtwin's Avatar
ksvtwin
I did not have time to work on this yet but I will post the results to help others.. i plan on putting new plugs in it and cleaning the maf sensor. i'm not so comfortable with the decarbon yet, i'll do that last if the other two don't clear it up. Thanks KS
Old Aug 24, 2004 | 07:48 AM
pawpaw's Avatar
pawpaw
When you get to the de~carb proceedure, IMHO, I'd put the old plugs back in before doing it, but then why not just go ahead & do the decarb, before you put those nice new plugs in & save yourself some time & aggravation.
Old Aug 26, 2004 | 07:41 AM
ksvtwin's Avatar
ksvtwin
I changed plugs (the old ones were gapped way too wide and worn), I put in a new air filter, pvc (because it needed it) and i cleaned the maf sensor. the sensor wasn't too dirty but i cleaned it anyway. I do not hear any pinging any more but it hasn't been very hot either. i'm hoping this fixed it. i'm going to torque the intake yet at some point and i'll keep you posted. KS
Old Aug 30, 2004 | 07:23 AM
ksvtwin's Avatar
ksvtwin
Follow up: I changed the plugs and cleaned the maf sensor. I did not torque the intake or decarbon yet. I have been driving it a lot on 87 octane and have not heard any pinging yet! Just letting everybody know how it went. thanks, Kent
Old Sep 7, 2004 | 04:36 PM
vintageant's Avatar
vintageant
Several weeks ago, I went through the procedure to decarbon as detailed in post https://www.ford-trucks.com/forums/showthread.php?t=100739&highlight=pinging+ Now about 900 miles later, sometimes upon starting up, the exhaust gives out great plumes of smelly grey smoke for about a minute, just as it did during the decarb process. Performance doesn't seem affected. What gives?
John
1993 Aerostar 4.0 145k miles
Old Sep 7, 2004 | 04:44 PM
pawpaw's Avatar
pawpaw
Well John I don't rightly know, did you clean or change your spark plugs afterwards??? Hope you changed the oil also, as both likely had plenty of carbon & chemicals on/in them.
Old Sep 8, 2004 | 12:39 PM
vintageant's Avatar
vintageant
Pawpaw - yup, changed the plugs and oil right after the decarbon.
This is what aerocolorado posted in the Aerostar Forum:
"Just a guess, but it would seem logical that you have loosened pieces of carbon and cleaner fluid lodged in either the catalysts or muffler (or both) that are periodically being burned off."
It happened again this morning. Just seems strange that nothing for 3 weeks/900 miles and then the smoking begins.
John
<!-- / message -->
Old Sep 8, 2004 | 02:40 PM
pawpaw's Avatar
pawpaw
Good idea on the oil & plug change IMHO John.
Well lets see, when you cleaned the MAF, was it before or after the decarbon proceedure????
If afterward, maybe somehow the MAF got a little contamination on the element.
Doesn't take much in the way of oil mist, dust, lint, even spider webs will upset it.
I suppose it could be deposits in the muffler letting go, hard to believe they've resided in the cat converter, at it's operating temperature, for 900 miles.
If it's starting, ideling & running ok, think I'd just watch it for a while & see what if anything transpires.
You might try repeating the 3 mile > 3600 RPM, blow out & see if that will clear it's sinuses. Any excuse to wind one out, RIGHT!!!!!
I can hear you now.....but officer, pawpaw told me to blow it out for 3 miles, at greater than 3600 RPM.... hehehe
Old Sep 8, 2004 | 05:27 PM
vintageant's Avatar
vintageant
MAF was cleaned AFTER decarbon. MAF actually looked very clean. Couldn't find denatured alcohol so used carb cleaner and then rubbing alcohol. No difference upon reassembly, and smoking didn't begin for another 2 weeks.
Will continue to monitor.
John
ksvtwin
Nov 3, 2006 09:10 PM
ksvtwin
Oct 11, 2006 09:03 AM
ksvtwin
18
Dec 27, 2004 02:12 PM
Hegemon
New York Chapter
Mar 31, 2004 06:42 PM
