Bronco II Ford Bronco II
No KOER codes
Old Aug 22, 2004 | 07:00 PM
nijwnfi's Avatar
nijwnfi
No KOER codes
My 86 Bronco II 4wd automatic will not display KOER codes. Nothing not even engine ID. I get KOEO and memory and timing check- thats it. I'm trying to fix a stuttering/ rich running after warmup problem and KOER codes may help. O2 sensor is new (Bosch) new hp fuel pump, regulator, map sensor, EGR solenoid, battery ground cable, fuel filter, dist cap, tfi module, rotor, plugs. Throttle position sensor checks good. Less than 700 mi on remanufactured engine. Fuel pressure was low now is OK. No leakdown after shut down. This problem is driving me nuts!
g_k50
1978 - 1996 Big Bronco
Jul 15, 2010 09:39 PM
CowboyBilly9Mile
Nov 2, 2006 05:03 AM
Truck Builder 1
Aerostar
31
Mar 27, 2006 09:50 AM
PWR
1983 - 2012 Ranger & B-Series
Feb 21, 2006 03:39 PM
sphann
Dec 27, 2004 08:23 PM
