Motor Silk??
Old Aug 21, 2004 | 12:31 AM
BLACK350/6.0L's Avatar
BLACK350/6.0L
Motor Silk??
I work on HMMWV's and know a senior technician at AM General (maker of the HMMWV has sent me this additive called (MOTOR SILK) it is a lifetime engine lubrication treatment he wants me to try in the engines and check out the performance gains just wondering if any here has tried it and what there opinion is of the product... Thanks in advance!!!
Old Aug 21, 2004 | 07:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I have never heard of "it"... HMMWV, what is that?
Old Aug 21, 2004 | 08:24 AM
jdadamsjr's Avatar
jdadamsjr
Tim....
not quite awake yet?
Hare in Texus we call that there lil grocery getter, Excursion speed bump thang the "HumVee"....
Here's more info:
http://www.altboron.com/products/
http://www.altboron.com/store/index.php/cPath/27
Old Aug 21, 2004 | 08:45 AM
huntercgr's Avatar
huntercgr
Tim.... not quite awake yet?
Here's a related article, not too much actual info. though.
http://www.detnews.com/2004/autosins.../c04-85958.htm
Old Aug 21, 2004 | 09:21 AM
SBV45's Avatar
SBV45
With the API CI-4 ratings and the complexity of additives, I am not sure I would put an additive in my truck.
What diesel engine is used in the hummer?
Old Aug 21, 2004 | 09:43 AM
IB Tim's Avatar
IB Tim
A ... S L O W ...one
Old Aug 21, 2004 | 11:19 AM
Flash's Avatar
Flash
Motor Silk shows to be a boron oxide in a 20w-50 petroleum fluid. They claim that the carrier fluid is synthetic so I would assume that it is a Gp III dino synthetic which doesn't make any sense as Gp III's generally do not support an additive package. Solvency reports come from Herguth Labs. I am not familiar with this Vallejo, Calif. based lab so I am not sure of their credibility. CAS # is 8002-05-9 for those that are interested. Boron is a good EP/FM additive that is found in more motor oils every day. It is expensive to include in an oil formulation. They may be assuming that if a little bit is good- a whole lot is better. From the info I have- the jury is still out. It certainly won't hurt your engine like a clorinated additive such as Dura lube, Prolong, etc. Considering the cost of $30. per pint, I think the advantages do not out weigh the cost. It should be mixed at the rate of 1 pint per 5 qts. Hope this helps.
Old Aug 23, 2004 | 03:26 PM
vellingapa's Avatar
vellingapa
GM owns Hummer. Last I heard they came with the older 6.5L Diesel. I don't think they have Duramax's yet in them but might be wrong.
Old Aug 23, 2004 | 07:35 PM
Frobozz's Avatar
Frobozz
High-Mobility Multipurpose Wheeled Vehicle. That's army-speak for "that newfangled Jeep replacement" - people tried their hardest to pronounce it, and came up with "humvee" which somehow became "hummer" which later became "Hummer-circle-r-trademark" when they started selling them to civilians.
Duncan
Old Aug 23, 2004 | 09:19 PM
IB Tim's Avatar
IB Tim
Cool....well now that I am a bit smarter.......let me tell you way back when...o-heck we just called them jeeps
panic
Jan 10, 2017 10:07 PM
DevilDocTater
Feb 19, 2016 10:01 PM
ImAGirl
Aug 3, 2015 03:13 AM
The Fool On Th Hill
21
Feb 25, 2012 06:33 PM
DeKuma
Oil & Lubrication
Feb 7, 2005 10:55 AM
