1994 Ranger Transmission Problem
Old Aug 20, 2004 | 11:52 PM
mattd860's Avatar
mattd860
Exclamation 1994 Ranger Transmission Problem
Hi. When it is below about 45 degrees, my transmission will not shift out of 1st gear until it warms up. I don't mean when the vehicle warms up, I mean after I've driven a good few miles. I've let the truck warm for over 30 minutes and the tranny still does the same thing. The fluid and filter have been replaced by a professional as well as the modulator not even 6 months ago. I brought it to the tranny shop for that same reason and when I drove off the lot it did the same thing. Is it something else? Any suggestions - I want to get this thing fixed before winter comes again
Old Aug 21, 2004 | 01:36 AM
Peter94's Avatar
Peter94
Did they just replace the tranny fluid and filter, or did they by chance do a tranny flush also. I would suggest it. Our D***e minivan started to have tranny problems, so we had a shop run some heavy duty tranny cleaner through it, and change the filter/fluid. Now it runs great (well, for a dodge). It might help your situation
Old Aug 21, 2004 | 08:43 AM
Bart99GT's Avatar
Bart99GT
It sounds as if something in the valve body is gummed up, or is binding until the expansion of the metals frees up the valve again. Flushing the transmission might clear up the problem, if it doesn't, the valve body will probably need to be dropped and checked for a binding or stuck valve.
Bart
Old Aug 21, 2004 | 09:16 PM
racsan's Avatar
racsan
i had a C5 (or C4 not really shure which) in a fairmont that would do the same thing. never did find out what caused it, car had just over 100,000 miles on it with a 200-6. i think it would be something sticking in the valve body.
Old Aug 21, 2004 | 10:11 PM
Vin 95's Avatar
Vin 95
Have you tried pulling it down in low and shifting it manually,mine wouldn't shift once and after manually running through the gears it shifts fine.
Old Aug 22, 2004 | 09:17 PM
mattd860's Avatar
mattd860
When I manually shift it into 2nd gear it will shift - however, if the tranny is not warm yet, when I shift it back to Drive, it will shift back into first gear.
Old Aug 23, 2004 | 11:53 AM
Vin 95's Avatar
Vin 95
That is strange,Have auto zone read the engine codes,the light doesn't have to be on to get a pending code.you may have a bad Throttle possition sensor,a bad TPS will tell the computor the engine is at idle and not shift properly.
Old Aug 23, 2004 | 07:29 PM
hreed's Avatar
hreed
One possibility is a bad vehicle speed sensor. Are you getting a CEL?
Old Aug 23, 2004 | 07:54 PM
mattd860's Avatar
mattd860
I know a lot about vehicles, especiall about fords, however I have never heard of a CEL. Or at least I've never heard of anything called that. If it is the check engin light than no, i'm not getting one. Otherwise, sorry, but what is a CEL???
Old Aug 23, 2004 | 08:24 PM
Ken00's Avatar
Ken00
CEL = check engine light.
Old Aug 23, 2004 | 08:39 PM
mattd860's Avatar
mattd860
would the TPS (Throttle Position Sensor) show up when I have my computer read? Are they cheap and/or easy to replace if needed?
Old Aug 24, 2004 | 12:35 AM
Peter94's Avatar
Peter94
I dont know about cheap, but they're like 2 bolts to get off, and its right on the side of the throttle body. Probably the easiest piece of equiptment to get at
Old Aug 24, 2004 | 07:07 AM
Bart99GT's Avatar
Bart99GT
If it can be manually shifted into 2nd gear, but immediately shifts back to 1st when put back in drive, then it probably is a sticking control valve in the valve body. When you shift manually, it bypasses some of the valves that control the automatic shifts.
Old Aug 24, 2004 | 09:01 AM
NorthPac's Avatar
NorthPac
I have a 93 Ranger and it does about the same thing when I first start the truck and leave I stop at a sign and the transmission will not shift. It takes about a min to engage to 1 gear to go. When the transmission warms up it works fine.
What I think is wrong with mine is that I took off the OEM tran cooler and the rad cooler lines and put on a old style HD cooler in front of rad. The OEM cooler I think was a thermo temp one that limited flow when it was cold. The new HD cooler I think is getting the tran to cold and it won't shift right when it cold.
One of these days I'm going to get a HD B&M tran cooler that has the thermo temp that limits the flow when its cold. I tow a trailer I need HD.
Hope these helps?
Old Aug 24, 2004 | 10:48 AM
Vin 95's Avatar
Vin 95
A bad TPS or VSS should show up when they read the codes.the TPS is $26 and the VSS is about the same,and both are easy fixes.Get the codes read first and see what you get.Auto zone will read them for free,so its affordable to check anyway. Post any code you get here,and we will try to help.
