462 Lincoln engine
Old Aug 19, 2004 | 02:50 PM
ms_michelle's Avatar
ms_michelle
Unhappy 462 Lincoln engine
Before everyone tells me this is not a 385 series engine, I already know that. Since there is not a board that covers these engines, and these engines are close in power and displacement to the 460 I thought perhaps that this would be a good place to start. I have a 462 Lincoln engine from a 67 Lincoln that I parted out several years ago. I knew the car and know that the engine is a good solid well running engine that produces gobs of torque. I am giving serious thought to putting this engine in my 55 F-600 replacing the 390 that now resides in it. This engine has a bellhousing that looks different to any Ford bellhousing that I have ever seen. I have the original C-6 tranny that was behind the engine, but I want to mate the engine to my truck four speed. Can anyone on this board tell me if anyone makes an adapter, or does anyone know of a bellhousing that will fit this engine where I can use a manual transmission with it? Also I need to know what if any flywheel will work with it?
Michelle
Old Aug 20, 2004 | 03:48 AM
scroob's Avatar
scroob
You would find more support in the Y block forum.
Old Aug 20, 2004 | 09:37 AM
ms_michelle
The engine is even futher removed from a Y block than the 385 series engines. I have Y block engines in the shop and there is nothing the same, These engines are even larger in size than an FE engines that replaced the Y block. I have made a post in the 401, 477, and 534 engine group as these engines are also closely related to them also.
Michelle
Old Aug 20, 2004 | 11:16 AM
scottie2hottie's Avatar
scottie2hottie
Good luck with that, the MEL engines aren't terribly common and I've heard they're hard to get quality aftermarket parts for, although I've never owned or worked on one myself.
Scott
Old Aug 20, 2004 | 12:32 PM
82F100SWB's Avatar
82F100SWB
IIRC, the MEL is considered a big block FE. A good friend of mine had had a 430 in a 66 F100 in the late 60's, and he's pretty sure he used a 352 bellhousing and flywheel on it...
Old Aug 20, 2004 | 12:39 PM
BB's Avatar
BB
Michelle, check out this thread:
https://www.ford-trucks.com/forums/s...2+bellhousing+
Old Aug 21, 2004 | 11:00 AM
ms_michelle
Thanks for the info guys, as usual you are a big help. I do have a manual bellhousing in the shop for a 429, 460. I will get it out sometime this week and see it it will fit up. I will post my reselts here for you.
Thanks again,
Michelle
Old Aug 22, 2004 | 01:07 AM
scroob's Avatar
scroob
My point about the Y block forum was that it's inhabited by more people who know these engines. There have been a number of discussions about the MEL there.
Old Aug 25, 2004 | 06:11 PM
Rob H's Avatar
Rob H
Another MEL forum
Have You tried the MEL forum at http://www.network54.com/Forum/257364?
There's some sort of sign-on screen , but reload the page and it usually works...
Just my .01 cents
/Robert
ms_michelle
401, 477, & 534 SD Engines
52
Jul 15, 2025 10:59 PM
Scramblermaster
80
Mar 13, 2013 06:23 PM
pcmenten
20
Aug 8, 2007 06:08 PM
rcrowder
2004 - 2008 F150
18
Feb 14, 2007 06:11 PM
Andy W
Oct 31, 2002 01:27 AM
