Sponsored by: Real Truck
Maryland Emissions Test
Old Aug 19, 2004 | 11:00 AM
steamer1234's Avatar
steamer1234
Question Maryland Emissions Test
Can anybody tell me, if I can pass a MD emission test with the ABS light on? 2000 Ford F250 SD 5.4L 4X4
Old Aug 19, 2004 | 02:23 PM
Pikachu's Avatar
Pikachu
If its just an emmissions test, I don't see what the ABS system would have to do with it.
Old Aug 19, 2004 | 03:24 PM
Ironweed's Avatar
Ironweed
Maryland resident as well. I've got the brochure in front of me, and it says your vehicle cannot be tested if:
" The exhaust system has holes or is leaking
Gasoline, oil, or coolant is leaking
The gas cap is missing
Your vehicle is emitting visible smoke for more than 10 seconds at any time
There are warning lights on the dashboard illuminated, such as the brake, temperature or oil"
They will plug into your computer and the code causing your ABS light to illuminate will cause you to fail the test (according to what they say in the brochure, at least). You may be able to reset it long enough to pass, but you should probably get it checked out (could save your truck, your life, or some else's)
Old Aug 19, 2004 | 03:28 PM
Pikachu's Avatar
Pikachu
Sounds to me they need to change the name of it to a "safety inspection with an emphasis on emissions".
Old Aug 20, 2004 | 06:38 AM
steamer1234
MD Emission
I know my ABS module is bad. Just wanted to prolong the big bucks for a new one.
Thanks
Old Aug 20, 2004 | 07:07 PM
350cubby's Avatar
350cubby
Hey there. I live in Baltimore and just had my truck tested at the emissions's place. I thought they would have plugged in the OBDII connector, but for some reason they didn't. They put it on the "treadmill". So I dont think you should have to worry about the abs light being on, especially if they put it on the treadmill.
Old Aug 21, 2004 | 12:22 AM
psdpower's Avatar
psdpower
I haven't been to an emissions test in years ( diesel ), but they will not put your truck on the dyno with lights on the dash lit. Did you try replacing the sensor in the rearend. It's about $20 from Ford and takes about 5 min. to replace. That solved my ABS light problem on my 99 F250.
Old Aug 21, 2004 | 07:27 AM
slc10844's Avatar
slc10844
You might try calling the emissions test stations you plan on going to. They should be able to give you a definite answer. I can't imagine an ABS light causing a problem on an emission test.
xon2013
32
Nov 5, 2016 07:59 AM
oakleysfire
6.4L Power Stroke Diesel
Jan 26, 2016 12:31 PM
D8chumley
2009 - 2014 F150
20
Apr 28, 2013 06:56 AM
BAD RONALD
Mar 7, 2012 08:16 AM
scottman70
Sep 15, 2009 09:32 PM
