Sponsored by: Real Truck
Super Duty Thunk
Old Aug 8, 2004 | 05:52 PM
dbalke's Avatar
dbalke
Super Duty Thunk
In a post last fall, I described a thunk i heard under the right front side of my SD. Over the winter that thunk went away, but has come back with a vengence. Gonna take in to the dealer sometime this week. Hopefully they will be able to issolate it.
Until then, any ideas?
Old Aug 8, 2004 | 05:57 PM
boxcar1974's Avatar
boxcar1974
Mine does it in the first few minutes after start up. It only happens when the heat or A/C is on. There is a valve that opens or closes and makes a thud. Sometimes it is relatively quiet and there are other times it is loud enough to startle you.
Old Aug 8, 2004 | 06:02 PM
dbalke's Avatar
dbalke
Originally, mine only did it right after start up shortly after turning on the A/C (within 5 minutes of starting). But lately it happens with or with out A/C, and often after driving for 15-20 minutes.
Old Aug 8, 2004 | 06:25 PM
wmcutter's Avatar
wmcutter
I get the thunk on the right front side too. Happens when I start up but not every time. Turn the key and "thunk" one time and the motor starts. Always wondered what it was. Since it didn't seem to harm anything, I ignored it. Be interested to see if there's some explanation.
Old Aug 8, 2004 | 06:45 PM
dbalke's Avatar
dbalke
I will try to find out when I take it in. Gonna try to get an appointment this week, but may have to wait until next week.
Old Aug 9, 2004 | 12:47 PM
Big Orn's Avatar
Big Orn
Have you guys done a search for this?
It could be the airflow door in your air conditioning system.
There's a fix here somewhere, but I can't think of the term to use right now.
Anyone remember the correct term for that sticking door?
I got CRS....
Old Aug 9, 2004 | 08:35 PM
joe blow's Avatar
joe blow
Talking
If I am not mistaken, it is called a "blend door".
Old Aug 10, 2004 | 06:30 AM
Aldo1's Avatar
Aldo1
I have been to the dealer for this and it was verified as the blend door. I am told that as soon as the vaccume motor gets enough pressure the door releases. Take note that it wont do it if shut off and restarted within 5 min. But after 5 min. or so of sitting it will bleed off and do it again - Still to this day it scares the ***** out of me if I am manuvering in a tight space and forget about the little thump in the dash, sounds like I hit something when it lets go. Was told this is common and not abnormal - of course it is! ! !
Old Aug 10, 2004 | 09:53 AM
fordowner4life's Avatar
fordowner4life
I had the same thunk in other trucks also. Most recently a rainger.
I think Ford used all of the same components for its hvac systems.
Old Aug 20, 2004 | 09:13 AM
dbalke's Avatar
dbalke
blend door
Well, I took it in today, and was relieved to find that it is, in fact, the blend door making that noise.
Old Aug 20, 2004 | 10:12 AM
04 SD's Avatar
04 SD
If the blend door is making the noise.. What did the dealer say about getting fix?
Old Aug 20, 2004 | 08:48 PM
FortyFords's Avatar
FortyFords
Turn all heat/ac controls to off position before turning truck off
Rich
Old Aug 21, 2004 | 07:02 AM
Nitramjr's Avatar
Nitramjr
The dealer is saying turn everything to "off" but if you do that, especially in the summer, you will have one hot vehicle when you get out of work. "OFF" will close the vent and allow no heat to escape unless you leave a window open too. I would leave it in "VENT" and live with the thunk.....I think.
Old Aug 21, 2004 | 09:24 AM
91s10350's Avatar
91s10350
I was told it was the ABS module turning on.
