Starting Question
Old Aug 18, 2004 | 09:19 PM
Lifted4Fun's Avatar
Lifted4Fun
Starting Question
Sometimes when starting my 01 7.3 it makes a clicking sound that sounds like it is coming from behind dash. I wait for wait to start light to go out, then start. I've had the batterys,starter and alternator all checked. Checked good! If you have any ideas let me know. Thanks. Also doesn't cause any codes or show any codes.
Old Aug 19, 2004 | 04:11 PM
Lifted4Fun's Avatar
Lifted4Fun
No One has any ideas?
Old Aug 19, 2004 | 04:53 PM
johnsdiesel's Avatar
johnsdiesel
Maybe you're hearing the glow plug relay activate. It's hard to tell without actually hearing your truck, but that would be my guess. I can hear mine when it comes on.
Old Aug 20, 2004 | 05:32 AM
slc10844's Avatar
slc10844
Most likely the glow plug relay. Even when the light goes out the relay can remain active.
Old Aug 20, 2004 | 12:04 PM
Lifted4Fun's Avatar
Lifted4Fun
I don't hear the clicking till I actually turn the key to start the truck. Could it still be the glowplug relay? Could it be going out(glowplug relay)?
Old Aug 23, 2004 | 05:12 PM
Nickiboy's Avatar
Nickiboy
Im having a similiar problem ....... more like a buzzing sound when cranking ...... Like a vehicle with a dying battery would make, but yet it still cranks up strong....... Im kinda wondering if the starter solonoid may be on the way out
Old Aug 23, 2004 | 05:36 PM
Lifted4Fun's Avatar
Lifted4Fun
Yes it does act as if the truck has dying batteries.
Old Aug 23, 2004 | 07:06 PM
slc10844's Avatar
slc10844
If it makes the noise after you turn the key to start and before the starter engages, I would have a load test performed on the batteries.
Old Aug 24, 2004 | 08:45 AM
Lifted4Fun's Avatar
Lifted4Fun
Mine don't make the sound till engaging the starter. Mine hasn't made the sound for about a week now. Hope it has resolved itself.
Old Aug 24, 2004 | 03:25 PM
slc10844's Avatar
slc10844
It's just giving you a false sense of security.
Old Aug 25, 2004 | 06:35 AM
woody_f250's Avatar
woody_f250
That sounds like the same thing mine is doing. Will it start while making the sound? Whenever mine makes the sound it won't start and I have to cycle it again. I'm pretty sure mine needs new glow plugs, however I'm still not sure what it is making the sound.
Old Aug 25, 2004 | 08:00 AM
Lifted4Fun's Avatar
Lifted4Fun
When it starts making the sound I let off. Cycle it and try it again. It usually will not make the sound after cycling once,but sometimes it takes a few times cycling. Then starts no problem. Have never kept cracking the starter when making the sound, so don't know if it will start while making the sounds.
Old Aug 25, 2004 | 08:46 AM
woody_f250's Avatar
woody_f250
Sounds like the same thing to me. Mine stopped doing it for a while, now it's come back and getting worse.
Old Aug 25, 2004 | 09:07 AM
Lifted4Fun's Avatar
Lifted4Fun
Have you figured out what the problem is Woody? If its glow plugs I need to get them replaced before winter gets here.
Old Aug 25, 2004 | 04:21 PM
woody_f250's Avatar
woody_f250
I'm going to check my glow plugs here in the next week and I'll let you know. The more and more I learn, I'm starting to lean towards new batteries.
