NO HEAT only blows cold
Old Jan 25, 2008 | 01:50 PM
nbondy2's Avatar
nbondy2
i have a 1996 f 150 4x4 with 351w and the heat was working perfectly then i started it up the next morning and it wont blow hot air checked the collant and it is fine any suggestions would be appreciated
Old Jan 25, 2008 | 01:52 PM
tfowler306's Avatar
tfowler306
check the vacuume feed to the dash. if you dont have vacuume under the dash it wont open the air diverter to alow the fan to blow through the heater core.
Old Jan 25, 2008 | 04:23 PM
wde3477's Avatar
wde3477
Suggest to verify that both heater hoses are hot to ensure flow is going through the core. Next would be a likely temperature blending door problem.
Old Jan 25, 2008 | 05:22 PM
tucker1999's Avatar
tucker1999
On my 1995 F-150 4x4, I had the same problem and it was in the switch in the dash. Ended up replacing the switch.
Old Jan 25, 2008 | 05:32 PM
Brawny's Avatar
Brawny
Stuck thermastat maybe? Does the truck warm up to its normal operating temp? If not thats where I would look.
Old Jan 25, 2008 | 09:44 PM
winfordr's Avatar
winfordr
I vote for the vacuum problem, either the switch, its connection or a line. Can you find the vaccum supply under the hood and make sure it is good to where it goes through the firewall? That would be much easier to check than anything under the dash.
coachblue502
May 5, 2015 04:53 AM
chasehoe
Mar 27, 2015 12:43 PM
63ferd
Feb 24, 2014 01:04 PM
grip1968
Nov 27, 2013 08:49 AM
psvienneau
Nov 27, 2011 03:06 PM
