Oil & Lubrication
grease question?
Old Aug 18, 2004 | 02:44 PM
aztec12's Avatar
aztec12
Question grease question?
since i do my own oil changes i do not grease anything under the truck. is there anything or i'm i suppose to grease something.tks
Old Aug 18, 2004 | 07:08 PM
peppy's Avatar
peppy
Depends, do you have grease fittings? Cant much tell ya w/o the make/model/year.
Old Aug 19, 2004 | 10:14 AM
jim henderson's Avatar
jim henderson
There are lots of things under the truck that need to be greased. Of course any grese fitting is obvious. Some newer trucks don't have the fittings, so they are permanently sealed.
Other things needing grease include the parking brake cable, and spots where cables slide, the shift levers on the tranny, probably a few other things I missed. Look around, if it looks like it needs grease give it a shot. I like spray white lithium grease for most items that don't have a fitting. Good on door hinges, locking latches etc.
Good Luck,
Jim Henderson
Old Sep 22, 2004 | 12:02 AM
Loan Ranger's Avatar
Loan Ranger
The newer the truck, the fewer the grease fittings. (I really do not like that very much. Oftentimes, "lubed for life" means a very short life, I feel.) But, if it has a greae fitting, by all means grease it--and do so at every oil change.
Ford's molybednum disulfide grease--available in tub or in tube for a grease gun--is really marvelous stuff. Of the strictly automotive greases, I truly think it has no equal. (Of course, there are some aircraft-grade greases out there that are awesome. Some of the aftermarket greases--such as Lucas X-tra Heavy Duty--are fantastic.) Still, the moly grease is available from Ford (of course) as well as Valvoline, Tractor Supply, and Wal-Mart. Quaker State offers it as well. It is really THAT good!
Tofan
6.7L Power Stroke Diesel
Aug 20, 2014 08:47 AM
bigbubba87
Nov 12, 2012 08:30 PM
dabaws
Sep 24, 2011 11:50 PM
bassaway
Oil & Lubrication
Jun 2, 2005 12:47 PM
jeffjr
Mar 5, 2005 04:34 PM
