390 Compression, HP and Torque Est please
Old Aug 17, 2004 | 06:38 PM
Azguy54's Avatar
Azguy54
Question 390 Compression, HP and Torque Est please
Ok guys, got the bottom end together so here goes:
Deck Clearance: .030 (as measured)
Head Gasket Bore: 4.300 avg. (Victor Seal) Not round so est. of avg bore
" " thickness: .041
Piston Volume: 10.8 ccs
Cyl Bore: 4.080 (.030 over)
C8AE-H Heads 68.1 to 71.1 (From Steve's book)
Valves: 2.09 / 1.65
Cam: Comp Cams XE262H-10
Specs: Gross Lift, Int. .513 / Exh. .519
Duration @ .006 Tappet Lift, Int. 262 / Exh. 275
Valve Timing OPEN CLOSE
@ .006 Int: 25 BTDC 57 ABDC
Exh: 72 BBDC 23 ATDC
Duration @ .050 Int. 218 Ext. 224
Lobe Lift Int. .2980 Ext. .3010
Lobe Seperation 110.0
Performer RPM
Edelbrock 600 CFM
Hedmen Elite Headers
Hope that's all you need. Thanks guys, this site has been huge in helping me decide things on this build. Got a ways to go but it sure has been a blast as well as a great learning experience. My son loves coming over and working on this truck and that is a big big plus too. Hell, who knows, someday we may even drive the thing, ha ha.
Old Aug 17, 2004 | 07:17 PM
rusty70f100's Avatar
rusty70f100
I'll get back to you with the desktop dyno estimate since I'm at college now, but I can tell you something right now. If you're gonna run those stock heads with the performer RPM manifold, you'll have to port the heads to match, otherwise it wont flow good and it WILL hurt performance. See the thread "Porting Revisited" for more instructions.
Old Aug 17, 2004 | 08:15 PM
polcat's Avatar
polcat
I am running the same heads and intake Azguy54 I had to port out the intake side to get it to match. I am running a larger cam, but I can tell you a larger carb will also help if your looking for a lot of HP. Sounds like you got a good setup good luck!!
Old Aug 17, 2004 | 08:34 PM
Azguy54's Avatar
Azguy54
I took the intake gaskets and it looks as though the bottom of the head ports is slightly above the gasket. To check it out I made a template of the intake and there isn't a lot of "porting" to be done it seems. Maybe just "chamfering" the areas to match? I thought there would be a LOT more difference but there really isn't. am I missing something here?
As for the carb, we were looking at the 750 but we'll see how it runs this way first. If it seems to "starve" then we can take a look at the bigger carb. We were only using thsi carb because it came with the truck but was mounted on an old Edelbrock Streetmaster that has a hole in the water jacket just above the thermostat housing.
Old Aug 17, 2004 | 09:08 PM
polcat's Avatar
polcat
I ran a holley 600cfm on mine for a while it seemed to run good , yeah your right about the heads that will all you need I went a head and ported the hole head on the intake side but went to far on the exhaust side so I am making some more changes on my heads by installing the bigger valves. Mine is mostly set up for very little street and more race I am running a Comp 292H cam it has a very radical idle would not suggest it for a everyday driver.
Old Aug 17, 2004 | 09:28 PM
Azguy54's Avatar
Azguy54
My son will be driving mostly street with this one. Not looking to knock socks off but run "nice". Hence the mild build. I did several sets of small block heads back in the day when I was young and foolish. Concentrated on the exhaust ports more so then the intakes due to messing with the atomization of the fuel/air mixture. I take it that the same would hold true here?
Old Aug 18, 2004 | 09:18 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well this is what the DD is telling me? I used 70ccs for the heads for an average..
CR- 9.83
Cam @ .006"
335HP @ 4500RPM
459LBS of torque @ 2500RPM
this is just a guesstamate...because there are know previsions for stock heads with large valve's
Some one who has a flow chart for the heads with the larger Valve's and the flow chart for the RPM intake, will come much closer...
Russ
Old Aug 18, 2004 | 09:40 AM
Azguy54's Avatar
Azguy54
Cool, thanks Russ. Numbers look fine to me, mild, not wild. CR looks good too. Right in the range where I wanted to be. Should be able to run pump gas easily and he won't be able to get too crazy with it. Thanks guy
George
Old Aug 18, 2004 | 12:05 PM
rusty70f100
I'm getting 9.36:1 compression, and 330hp @ 4500rpm, and 435ft-lbs @ 2500rpm.
Old Aug 18, 2004 | 12:23 PM
RapidRuss's Avatar
RapidRuss
Kurt, your probably alot closer than I am, because i didnt figure in the deck clearence?
NIdude
Apr 14, 2015 10:25 PM
SCRebel
1997 - 2003 F150
Dec 28, 2013 09:56 PM
mustang81
19
Jan 23, 2013 09:14 PM
highboy 74
Aug 19, 2005 07:21 PM
78 460 5 speed
Jul 17, 2003 08:40 AM
