429 storage preparation
Old Aug 15, 2004 | 06:52 PM
75crew's Avatar
75crew
I am yanking my 429 to do a frame off and am unfamiliar with preservation requirements for the engine. It will likely be sitting on a stand for 2 years and I would like to avoid any unpleasant surprises. Thanks.
Old Aug 15, 2004 | 07:19 PM
drewcoolness99's Avatar
drewcoolness99
try coverign any openings with tape and plastic and put it in a trashbag on the engine stand. don't know much about storing engines for that long though.
Old Aug 16, 2004 | 02:47 PM
Ecuri's Avatar
Ecuri
two years in your climate isn't that long. You just want to keep the valves/bores/cam from rusting. Spin it by hand and spray some LPS 3 down the intake and in the EX ports (store the carb seperate, it is a whole other issue) to coat the valve seats etc. Remove the rockers and get all the valves seated at once (this is good for the springs also to store 'em relaxed.) Put some clean oil in it. Turn the engine upside down on the stand once in both directions to coat the bores... let it sit so oil runs up inside all the bores... flip it over every 3-6 months... and as recommended tape it and bag it to keep moisture out. PS when it is sitting upside down you will find out what shape the valves are in! Pull the plugs when you spin it for the restart and clear any large puddles.
taylorbickett5
Ford Truck Parts for Sale
May 13, 2015 05:04 PM
429thunderjet93f350
Mar 27, 2015 09:47 PM
nothercrash
Sep 23, 2010 10:43 PM
tess100
Jan 1, 2005 11:37 PM
tess100
Feb 6, 2004 04:26 PM
