gets hot when i drive
Old Aug 15, 2004 | 03:39 PM
evan250's Avatar
evan250
Question gets hot when i drive
I have a 1994 E250 econoline van. It can run at a stand still and never over heat. When I drive it overheats. Any help would be appriciated.
Old Aug 15, 2004 | 08:25 PM
Dealford's Avatar
Dealford
Welcome to FTE!
Start by servicing the cooling system. Have it flushed & put a new thermostat in.
AL.
Old Aug 15, 2004 | 11:24 PM
mako5972's Avatar
mako5972
You may also want to make sure the transmission has the proper amount of fluid. A hot running transmission will make you overheat also. Think about adding a transmission cooler. That will lower the transmission temperature considerably thus making the engine cooler in the process. This may not be your problem, but it will help.
Old Aug 15, 2004 | 11:31 PM
mako5972's Avatar
mako5972
Are you running the stock fan ie clutch fan? Sometimes the fan clutches go bad and need to be replaced. Check the fins in the radiator and make sure that they are free from obstructions ie lots of insects, paper etc.
bizzelj
1983 - 2012 Ranger & B-Series
Feb 27, 2015 04:36 PM
AlexGardnerf-250
Dec 13, 2013 08:35 AM
stev3-o
May 18, 2008 05:35 PM
evan250
Aug 20, 2004 08:50 PM
sud z
Oct 15, 2002 01:16 PM
