ignition switch ?
Old Aug 14, 2004 | 06:53 PM
boond0cksaint's Avatar
boond0cksaint
ignition switch ?
went out this morning to start my 78 4x4 (400) duraspark2, and noticed the idiot light on like the key was in the run/start position, but it was off. when i turn it to the accy. position the light stays on. when i put it in the off position the light is still on. when i go to start the idiot light dims(dead battery i assume) not even a click off the solonoid.seems like the switch to me what do you all think? appreciate any feedback
Old Aug 14, 2004 | 09:26 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Yep, it has to be the switch. There's a possibility that there's a short in the wires behind the switch, but I'd replace the switch first.
Old Aug 14, 2004 | 09:59 PM
ranger429's Avatar
ranger429
idiot light
Which idiot light?
It could also be bad diode's in the alternator causing a short which is draining your battery.
Old Aug 15, 2004 | 04:53 AM
boond0cksaint
Originally Posted by ranger429
Which idiot light?
initial battery light. am going to replace the switch and check all my grounds, slap another battery in and check the alt. thanks
Old Aug 15, 2004 | 08:08 AM
Jimbare's Avatar
Jimbare
all alone in the world
replace the voltage regulator with a known good one first. shorted voltage regs will do that also.
jim
newfordy
1997 - 2003 F150
Nov 9, 2014 06:29 AM
wr310rdr
Jun 24, 2013 04:13 AM
expydaddy
Jul 7, 2012 11:39 AM
Cap'nDewie
Dec 3, 2010 06:27 PM
robe
Mar 26, 2010 10:39 AM
