Airaid Question
Old Aug 14, 2004 | 02:07 PM
sawblade's Avatar
sawblade
Airaid Question
I am looking into purchasing an airaid cold air intake for my 04 5.4 but i heard that some people were having problems with the check engine light coming on after they had install it has this been fix yet?
Old Aug 14, 2004 | 07:39 PM
ctfordguy's Avatar
ctfordguy
Installed one and never had any problems with the check engine light in a little over 4000 miles. Just make sure to clean out the tube before installing.
Old Aug 27, 2004 | 04:15 PM
HawaiianStyle's Avatar
HawaiianStyle
CT, Hows your intake doing, have any problems to-date?
Old Aug 27, 2004 | 07:10 PM
ctfordguy's Avatar
ctfordguy
None yet, now at 6500 miles. I did however blow a coil and need all the spark plugs replaced. I would reccommend not putting any additives in the gas.
Old Aug 27, 2004 | 07:18 PM
HawaiianStyle
Awesome, Thanks for the info! ordered mine should be here monday. BTW did you change your exhaust to complete the package?
Old Aug 27, 2004 | 07:22 PM
ctfordguy's Avatar
ctfordguy
Of course, check out my gallery. I installed an Areoturbine. Basically a $200 piece of straight thru pipe. Sounds awsome.
Old Aug 27, 2004 | 07:30 PM
HawaiianStyle
howz your mileage and performance? Nice setup in the gallery too!
Old Aug 27, 2004 | 07:38 PM
ctfordguy's Avatar
ctfordguy
Performance is good, but the little bit of power the mods add it is hard to notice. Mileage is ok 11-12 with about 70% city and the BFGs. 14-15 on the highway with the BFGs and basically empty. 15-16 on the highway with the 'car' tires and empty. I have the 4.10 gears.
I had the PCM reflashed at 2500 miles and saw a hugh (1-2 mpg) increase. As for the what the mods did hard to tell.
Old Aug 27, 2004 | 08:25 PM
HawaiianStyle
How much for the Airaid? I was kinda bummed with MotorHaven. I called to get a price on the kit, informed the customer rep I'm a FTE member, she tells me "What's That?" huh, anyway, I explained to her that I got a message here on FTE that the online price was incorrect so I was calling to get the right numbers, she asked if I just called, "not me, first time here sorry", but the price she gave me was a tiny bit under the retail which was still almost $100 more then the other part store I contacted online. I really want to support MotorHaven but the prices has to be a little more competative. I asked her if she was correct about the cost she said yes, I told her but isn't that a little steep? she said.... yea, I guess???
Thank you for the info, bye bye now!
Old Aug 27, 2004 | 11:39 PM
chrish2's Avatar
chrish2
Did any of you guys notice a real big difference in the intake,,,, I've read a lot of defferent responses to this... Some say yes others say not worth the money....
Also,,, anyone do the throttle body spacer, and notice a difference there????
thanks,,
Chris
Old Aug 30, 2004 | 04:13 PM
superdarren's Avatar
superdarren
Thumbs up definently a difference
I installed a borla exhaust at about 5,000 miles and did not notice much of an increase in power. It sounded great but that was about it. Then around 10,000 I added the airaid and Wow! I don't know if it was just the airaid or the combination of that and the borla, but there is allot more kick when I hit the gas now. Plus it sounds a little louder too.
Old Aug 30, 2004 | 06:36 PM
Black2004FX4's Avatar
Black2004FX4
thanks for the reply, that finally answered one of my many questions
Old Aug 30, 2004 | 06:39 PM
old wrench's Avatar
old wrench
Sometimes you have to pull the mass air flow sensor and clean it with an electronics cleaner and unhook the battery to let the system reset. It is casued by to much oil on the air filter.
Old Aug 30, 2004 | 09:33 PM
SQCRUSE's Avatar
SQCRUSE
OLD WRENCH,
Could you elaborate on the process you are describing for the mass air flow sensor.THANKS!
Old Aug 31, 2004 | 09:57 AM
old wrench's Avatar
old wrench
The mass air flow sensor is located on the air intake pipe drivers side just before the turn down to the throttle body. This is out of the instructions with a pic of it, Disconnect the factory mass air flow connector on the driver’s side by releasing the red retaining
clip. Remove the factory mass air flow sensor and retain for later use. See Fig#1
You can clean it with a spray electronics cleaner, let it air dry and reinstall it, by unhooking the battery for more than 30 seconds it will let the system reset. When you clean your air filter spray it real lite with the oil, the least little contamination of oil on the sensor will cause it to read incorrect, that will cause the check engine light to come on. Hope this will help you.
