coil pack firing order help
Old Aug 14, 2004 | 04:01 AM
rsat61's Avatar
rsat61
Question coil pack firing order help
Does anyone know what order the coil pack on the 4.2 fires in. I inherited a job where the coil had been removed and now I need to reconnect the plug wires. The posts on the coil are numbered- do the wires follow the same order
(eg #1 cyl to #1 post) or does the coil fire in a sequence like a distributor and the wires are connected to match the firing order ( eg #1 cyl to #1 post, #4 cyl to #2 post, #2 cyl to #3 post, etc)
Old Aug 14, 2004 | 01:16 PM
f100guy's Avatar
f100guy
the cylinders go from #1 being the first plug on the pass. side to the #6 cylinder being closes to the brake booster. for some reason #6 on the coil pack is in the middle instead of the end of the pack but it is numbered on the pack so no problems there. am i being understandable.
Old Aug 14, 2004 | 05:36 PM
Tom's Avatar
Tom
According to the diagram I have, the coil pack is set up exactly like the engine is. The one on the passenger side closest to the firewall goes to the cylendar on the passengar side closest to the firewall. The positions on the coil pack correspond to the positions on the engine.
Old Aug 14, 2004 | 05:41 PM
f100guy's Avatar
f100guy
i am going off of a 3.8 which is the same as a 4.2 but the coil pack is on the front of the engine and it looks like this.
coilpack
1.2.3
5.6.4
motor
3...6
2...5
1...4
Old Aug 14, 2004 | 06:19 PM
Tom's Avatar
Tom
you're right. I'm an idiot.
Sorry about the confusion, but after checking your last post, I didn't read the diagram right!
4x4 ranger guy
3.0L V6
Feb 3, 2026 11:42 PM
Ford97Ranger
1983 - 2012 Ranger & B-Series
Nov 1, 2019 11:54 PM
skoveng
Modular V10 (6.8l)
Oct 29, 2008 07:07 PM
lesser mike
Modular V8 (4.6L, 5.4L)
Oct 20, 2007 07:10 AM
havoxx33
3.0L V6
13
Jun 16, 2004 05:24 AM
