Windshield Washer Pump
Old Aug 13, 2004 | 06:26 PM
eandaauto's Avatar
eandaauto
I tried to install a washer/coolant resevoir off a 92 f150 in my 69 f250. I took the resevoir and the washer pump wiring and connector, and installed a new pump. doesn't work at all. Its not the switch or anything...because the universal pump i used to have still works on there. Is there a reason why this 92 pump doesn't work?
Old Aug 13, 2004 | 11:55 PM
Faithful Old Road Dog's Avatar
It could be just a bad pump on the 92. Are there just two wires? You can check the ohms or hook it up directly to your battery to see if it pumps.
Old Aug 14, 2004 | 12:18 AM
eandaauto's Avatar
eandaauto
Just two wires. Pump is new, but I'll try hooking it up to the battery. I just really like the bottle off the 92.
Old Aug 15, 2004 | 08:30 PM
idealtrucks's Avatar
idealtrucks
this is not really on this topic but i thought i'd ask here, does you're pump seem weak like it doesn't pump a lot? mine on my 1970 just barly does squirt some on the windshield.
Old Aug 15, 2004 | 10:39 PM
Check your nozzles to make sure they're not clogged up. Check the hoses for small leaks.
Old Aug 17, 2004 | 08:01 PM
baitmaster's Avatar
baitmaster
Just replaced the pump on my '72. When you look at the old one, you can see why they dont last very long. Usually corrosion gets to them, and they die.
jade79
Nov 13, 2011 08:01 PM
Johnny_r
Dec 4, 2008 08:45 AM
Desertwolf
Jul 20, 2007 12:47 PM
rudyexp
Sep 2, 2006 08:39 PM
bones68
Bronco II
Jul 5, 2006 09:24 AM
