Timing and EFI
Old Aug 13, 2004 | 02:14 PM
Dannym's Avatar
Dannym
Timing and EFI
I know how to check timing on a carb'ed engine and how to adjust it. Now with an electronic ignition, is there anything to check or adjust? ('87 302).
Old Aug 13, 2004 | 02:19 PM
beastybronco's Avatar
beastybronco
well i am going thru some serious timing issues so i dont know if u want to take my advice but i have a few LENGTHY post on this topic
https://www.ford-trucks.com/forums/s...d.php?t=270619
https://www.ford-trucks.com/forums/s...d.php?t=270266
they are long reads but maybe u can make sense out of them
Old Aug 13, 2004 | 02:29 PM
lmadore's Avatar
lmadore
Timing is adjustable.
Get a Chilton's or a Haynes manual.
You will need a timing light.
You will also need to locate the jumper on the spout connection located near the distributor. This jumper prevents the ECM from automatically adjusting the timing while you are adjusting the base timing.
