Clutch Helper Spring Help
Old Aug 13, 2004 | 01:57 PM
aesposito's Avatar
aesposito
I have a 96 250 153K with a 5 spd manual. My mechanic told me that my clutch helper spring was broken and that that is why it takes so much force to start the truck and shift. I have not found anything in my Chilton's manual about a "helper Spring" and need to know if that is what it is called and if it has any stock number.
Anthony
Old Aug 13, 2004 | 04:36 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Look at the very top of the pedal assembly, there is a black sping that hooks on the pedal on one end and bolts to a bracket on the other using two torx screws (T-25 I think). If that is the problem then just remove it, don't bother replacing it. I think the clutch feels much better without it.
cmurphy72
Nov 10, 2010 01:35 PM
low 66
Oct 23, 2010 10:31 PM
antunez13
Mar 30, 2009 01:59 PM
wbarton
All Things Towing
Nov 22, 2008 05:50 AM
bigdog13
Sep 29, 2005 02:08 AM
