Bronco II Ford Bronco II
What else to replace when replacing ac compressor?
Old Aug 13, 2004 | 09:58 AM
calzone's Avatar
calzone
What else should I replace when I replace the A/C compressor? What is all involved when replacing the compressor?
Old Aug 13, 2004 | 02:49 PM
Monty06's Avatar
Monty06
orings on hose fittings must be replaced with new ones maybe some refrigerant oil check the hoses for any cracks or tears
Old Aug 13, 2004 | 05:58 PM
Help I M Stuck's Avatar
Help I M Stuck
if the system has been empty or open for any period of time it's higly reccomended to replace the dryer..they rust out quickly inside when the system is opened or drained for any period of time. They are not that expensive..can be purchased at your local pep boys, advance auto, autozone..etc.
Old Aug 13, 2004 | 06:05 PM
1 TON's Avatar
1 TON
Don't forget your orifice / screen.
Old Aug 14, 2004 | 04:58 PM
Ken00's Avatar
Ken00
If your system is still charged you'll need to recover the R-12 before opening the system. You'll have to pull a vacuum on the system before recharging.
cridertj
Aug 17, 2016 10:24 AM
Binkowski
May 28, 2016 12:28 PM
coolfeet
May 21, 2016 06:43 AM
IHbase
Jul 24, 2015 07:37 AM
John R. Thomas
Jul 7, 2013 10:03 PM
